payment gateway without withdrawal option
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM payment gateway without withdrawal option
Viewing 1 reply thread
    • #116621
      nnbtechn
      Ok I have a custom gateway that does not support the vendors withdrawal function but will enable the vendor to be paid regardless which part of the code provided in your example will I have to edit out.
    • #118349
      Well, this is a sample for adding custom vendor payout gateway.
      This does not have any API integration.
      If you want to ad your own gateway then off course you have to edit this.
