Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Payment processor questions
- This topic has 15 replies, 2 voices, and was last updated 6 years, 7 months ago by
- December 29, 2018 at 4:00 pm #41682
suzanne
GuestWanting to set up and include following payment processor options:
1. Paypal Adaptive Payments – does this work with your wcfm-addons? I have ALL (free & paid) wcfm-addons installed (except – marketplace migrator)
https://woocommerce.com/products/paypal-adaptive-payments/ – so that works in the same way as Stripe Split Payment?2. Square Up – I am going to follow your instructions posted here
https://wclovers.com/knowledgebase/wcfm-marketplace-custom-payment-gateway-developers-guide/and use the sample plugin for adding custom payment gateway (mobile pay) you posted the zip file here
https://wclovers.com/forums/topic/how-can-i-add-woowallet-as-withdraw-payment-method/This will allow Square Up to then work with your wcfm-addons correct?
Can Square Up be set up to do the split payments like Stripe and PayPal Adaptive? Figured I should ask before creating the Square Up plugin….
I am going to use Stripe Split payment too.
- December 29, 2018 at 4:02 pm #41684
suzanne
GuestHere is WooCommerce Square Up link forgot to add it above
https://woocommerce.com/products/square/?utm_source=WooThemes&utm_campaign=f2d46aca5e-Episodic+-+Square+launch+-+July+2016&utm_medium=email&utm_term=0_13860df971-f2d46aca5e-242307917&mc_cid=f2d46aca5e&mc_eid=db7b047b07 - December 31, 2018 at 3:07 pm #41818
https://woocommerce.com/products/paypal-adaptive-payments/ – so that works in the same way as Stripe Split Payment?– You can’t use this anymore as PayPal’s adaptive API now deprecated.
https://wclovers.com/knowledgebase/wcfm-marketplace-custom-payment-gateway-developers-guide/– Here is a sample custom payment gateway – https://drive.google.com/file/d/1QkX7-ptpvdYyYJ8mm7Z1qk1qws6fLYFS/view?usp=sharing
You may check this as well.and use the sample plugin for adding custom payment gateway (mobile pay) you posted the zip file here
https://wclovers.com/forums/topic/how-can-i-add-woowallet-as-withdraw-payment-method/– Woo Wallet will add this support in their next update.
- January 2, 2019 at 1:33 am #41963
suzanne
GuestYour addons work with woo wallet? I havent heard of it. Is it this https://wordpress.org/plugins/woo-wallet/ ?
- January 2, 2019 at 4:41 am #41967
It works and Woo Wallet will make this part of their core in next update.
In fact they already released in GIT.Thank You
- January 7, 2019 at 5:46 pm #42534
Suzanne
GuestI edited the mobile pay zip file you gave for the example and I am trying to add Square Up as a withdrawal option.
I changed the file name part mobilepay.php to for example wcfm-pg-squareup.php
changed the variables wcfmmp to wcfmsu and WCFMmp to WCFMsu
changed the variables WCFMpgmp to WCFMpgsu
went through the files and changed every Mobile Pay to Square Up
saved and created a zip file wcfm-pg-squareup.zip
Uploaded it as a new plugin and the site goes into 500 server error.Do I upload the files not as a plugin?
- January 7, 2019 at 5:46 pm #42535
Suzanne
GuestWoo Wallet for withdrawal only works for paypal.
- January 8, 2019 at 6:24 am #42605
Uploaded it as a new plugin and the site goes into 500 server error. – possibly edit not right. What exactly you want to change?
Woo Wallet for withdrawal only works for paypal. – not getting your this query clearly? Between, Woo Wallet new version already released.
- January 8, 2019 at 12:34 pm #42658
Suzanne
GuestI want to add Square Up as a payment processor option. Woocommerce supports Square Up (I have the Woocommerce Square Up Plugin installed) but it isn’t showing up as an option in the WCFM so I am trying to add it. I have a store that wants Square Up as their withdrawal payment option. I am trying to provide this option for them. Woo Wallet DOES NOT offer Square Up as a withdrawal option. Woo Wallet is not going to fix my issue and is not the solution for me. SO I am trying to figure this out using your instructions.
You provided a Mobile-Pay.zip file as the example.
The Mobile-Pay.zip file example – I made the following changes before uploading the newly created zip file:
I changed the file name(s) part mobilepay.php to for example wcfm-pg-squareup.php
saved and created a zip file wcfm-pg-squareup.zipAm I also suppose to do what is instructed on this page?
https://wclovers.com/knowledgebase/wcfm-marketplace-custom-payment-gateway-developers-guide/Thank you
- January 8, 2019 at 2:36 pm #42679
Send me your zip
- January 8, 2019 at 7:03 pm #42716
Suzanne
GuestThis reply has been marked as private. - January 8, 2019 at 8:27 pm #42725
Calvins Ongele
GuestI use WCFM Multivendor marketplace in my woocommerce site http://www.sansoko.com. It has been working fine until recently where the save button down the right doesn’t work. After changing settings when I press it, nothing happens and the changes are not saved. Thank you.
- January 9, 2019 at 7:23 am #42779
MemberHi @calvins,
Well, I think some JS error happening to your site.
Kindly check once using Google Chrome browser console.
- January 15, 2019 at 5:18 am #43561
MemberHi @suzanne,
Here is your updated plugin – https://drive.google.com/file/d/1A2q8UvR6WkKn7x-7yQCb6PlOr6GLQK4F/view?usp=sharing
- January 17, 2019 at 5:44 pm #44152
Suzanne
GuestThank you so much. It is installed and showing properly. Next to test 🙂
- January 18, 2019 at 5:06 am #44188
MemberGreat … you have to integrate Square API now.
- The topic ‘Payment processor questions’ is closed to new replies.
