Payments and dashboard
Viewing 0 reply threads
    • #136287
      Caron Warnock
      I have disables settings tab and wondered if there is a way to move the payments setup tab to the dashboard?
      If I have settings tab enabled the timeline mentions to add product description but there is no field to add this. #how do I get rid of this prompt? Or where is the field to update?
      Also is there a way to move the member profile setup section the tabs on the dashboard?
      Also with regards payment. Where do I set up direct charge for stripe?
      With regards, my products section on the dashboard is there a way to hide “all, published, draft, pending, archive” section as the vendor can only create 1 product? Can I hide showing 0 to 0 of o entries? And how can I hide the double line of product details? I tried #wcfm-products tfoot {display:none !important;} but it didn’t work??
      Thanks in advance
