Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › please I need help problem with plugins it miss up
- This topic has 44 replies, 2 voices, and was last updated 6 years, 4 months ago by
- January 25, 2019 at 7:27 pm #45205
ahmedkazom
Participanthi I have problems with plugins I don’t know what going on I have Frontend Manager Ultimate but when I install the marketplace it asking me for regular Frontend Manager not the Ultimate and the booking tap it now show up I don’t know what I have to do please help me and to get clear ideas this my inf to see by your self
thank you
- January 25, 2019 at 7:27 pm #45206
ahmedkazom
ParticipantThis reply has been marked as private. - January 25, 2019 at 9:24 pm #45222
ahmedkazom
ParticipantI fixed already but I have another problem how can I do costume field for specific products or Category I tried to make group in Product Custom Field but I don’t know how it work ?
thank you - January 26, 2019 at 7:03 am #45262
Please check this – https://wclovers.com/knowledgebase/wcfm-custom-fields/
And do not create custom fields as group, just create normal.
- January 26, 2019 at 7:01 pm #45365
ahmedkazom
Participantok I already read it but it no show on product page why ? and can I do costume field for specific products or Category with ACF costume field or toolkit ?
- January 27, 2019 at 8:12 am #45398
Are you using only WCFM Free version?
Well, you may create category specific ACF field as well. But you will also require WCFM Ultimate to have support for this in frontend dashboard.
Between, ACF also has no option to show those fields under Single Product page.
- January 27, 2019 at 8:58 pm #45482
ahmedkazom
Participantno am using wcfm Ultimate and I don’t understand is I can create specific category by ACF but in same time the field no show under Single Product page.i just confuse ?!
- January 28, 2019 at 6:03 am #45512
That’s great.
Please check this, I have created a ACF field group for “T-shirt” category – https://www.useloom.com/share/96e64e11c9714d5caffcf31d288898d2
- January 28, 2019 at 2:54 pm #45570
ahmedkazom
Participantthank you for that it very good for me but it not show under Single Product page ?
- January 28, 2019 at 3:34 pm #45573
MemberWhat is your WCFM and WCFM Ultimate plugin version?
- January 28, 2019 at 5:08 pm #45598
ahmedkazom
Participantthe last WCFM Ultimate version 5.3.1 and WCFM Version 5.3.1 too
- January 29, 2019 at 5:49 am #45649
MemberKindly show me ACF field group setting screenshot.
- January 29, 2019 at 5:08 pm #45719
ahmedkazom
ParticipantThis reply has been marked as private. - January 29, 2019 at 5:22 pm #45723
You have set up this perfectly and it’s working fine – https://www.useloom.com/share/ea8f025d3c3c4e73aed102fda3531d9f
- January 29, 2019 at 6:12 pm #45740
ahmedkazom
Participantthank you for your help but the problem its not showing on product page after publish it
- January 29, 2019 at 6:24 pm #45744
I mentioned you this first time you ask me for ACF –
“Between, ACF also has no option to show those fields under Single Product page.”
- January 29, 2019 at 6:39 pm #45745
ahmedkazom
Participantis there any way to show those fields under Single Product page.
and I have problem with your costume field when I choice tho show it on description the all product page it now showing and there is problem with visibility it not show on correct location. can you fix that please
thank you - January 29, 2019 at 6:41 pm #45746
Only option is WCFM own Custom field.
I will help you to show this at right position.
Create a field and tell me where you to show this?
- January 29, 2019 at 6:47 pm #45752
ahmedkazom
ParticipantI already created a field and you just check them with all visibility because I want to create same fields and show them in different locations
- January 30, 2019 at 4:25 am #45807
I want to know those locations? Take a single product page screenshot and mark those places. Send me that.
- January 30, 2019 at 5:46 am #45812
ahmedkazom
Participantmy friend all of them it show wrong position you have my website details you can check by your self
thank you - January 30, 2019 at 9:27 pm #45908
ahmedkazom
Participanthi any help please ?
- January 31, 2019 at 7:30 am #45962
Please send me your site details once more here – https://wclovers.com/woocommerce-multivendor-customization/
- January 31, 2019 at 7:30 am #45963
MemberWait, I got those.
- January 31, 2019 at 7:33 am #45964
Member - January 31, 2019 at 7:43 am #45967
ahmedkazom
Participantyes just at this position try all another position and you will see
thank you for your help - January 31, 2019 at 7:46 am #45971
ahmedkazom
Participantand why when I need to do it on iPad it not let me that.
and can you do more options like choice the page or category to show the field on them ? - January 31, 2019 at 8:16 am #45987
“yes just at this position try all another position and you will see”
– I am not getting your query. is this position right for you or not? If not, then where you want to show this?
- January 31, 2019 at 5:44 pm #46058
ahmedkazom
Participantplease just try all of positions and you will see what wrong and what about my question
thank you - February 1, 2019 at 4:08 am #46123
What seems wrong to you, I can’t understand. SO I am asking many time.
Please know me where you want to show those fields?
“can you do more options like choice the page or category to show the field on them ?”
– It’s not relevant here, product’s fields only visible under single product page.Thank You
- February 1, 2019 at 7:18 am #46144
ahmedkazom
Participantlike in picture. the on description on the top of description. it only one positions right the description it not working at all
thank youAttachments:
You must be logged in to view attached files. - February 2, 2019 at 3:39 pm #46304
MemberOk, so you want to show just below title.
Actually, there has option for this, but your theme has destroyed WC default hooks.
- February 2, 2019 at 4:58 pm #46325
ahmedkazom
Participantthere no problem with my site can you fix it this problem please
thank you - February 2, 2019 at 5:01 pm #46328
ahmedkazom
Participantand when I need to add or edit a costume field from iPad devise it not working can you fix this problem too please
thank you - February 2, 2019 at 5:07 pm #46331
Here is default WC hook behavior.
I have added custom field after “Product Title” – https://ibb.co/pL1kVfB
And it’s visible at exactly below title – https://ibb.co/bQX2dW3
Also, check where categories are visible. But in your theme it’s visible just below title.
- February 2, 2019 at 5:13 pm #46338
ahmedkazom
Participantcan you fix it please this very importing for my website
- February 2, 2019 at 5:14 pm #46339
MemberOk, sure. I will do this as per your theme’s hook.
Don’t worry, have a great weekend 🙂
- February 2, 2019 at 5:17 pm #46341
ahmedkazom
Participantthank you so much but what you mean my theme’s hook ?
- February 6, 2019 at 7:38 am #46834
“my theme’s hook” – it’s WP coding term, ignore that.
Please know me your site’s FTP details to do this.
- February 6, 2019 at 5:11 pm #46909
ahmedkazom
ParticipantThis reply has been marked as private. - February 7, 2019 at 2:51 pm #47032
MemberPlease do not submit such access openly.
Between, what is cPanel url?
- February 8, 2019 at 4:21 pm #47288
ahmedkazom
ParticipantThis reply has been marked as private. - February 8, 2019 at 5:18 pm #47293
Member - February 8, 2019 at 5:44 pm #47300
ahmedkazom
Participantthank you for your help but I still have problem showing fields on description
- February 9, 2019 at 4:59 am #47337
MemberPlease show me screenshot.
Well, I have set this as per your requirement – https://wclovers.com/wp-content/uploads/2019/02/fullsizeoutput_763.jpeg
- The topic ‘please I need help problem with plugins it miss up’ is closed to new replies.
