Possibility to chose between Radio-Buttons and Checkboxes in Vendor-Product Form
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Possibility to chose between Radio-Buttons and Checkboxes in Vendor-Product Form
Viewing 15 reply threads
    • #38566
      Hoody
      The Admin should be able to choose which taxonomies/Categories/tags are using Checkboxes (for multipe selection), and which should have Radio-Buttons for Single Select – I attached a screenshot ( https://prnt.sc/lo9ggx ) for better understanding.
      I also found a plugin that allows to do exactly what i want and it works perfectly in the normal admin backend-product-editor but it does not have an inpact on the WCFM Add-Product Form. Here is the Plugin: https://wordpress.org/plugins/radio-buttons-for-taxonomies/
    • #38583
      This will not work here , but you may restrict this to allow select only one taxonomy for each group.
      Do you have WCFM Ultimate? Then set Capability -> Category Limit -> 1
      Or, if you don’t have WCFM U then add this code for the purpose ->
      add_filter( 'wcfm_catlimit', function( $limit ) {
        return 1;
      }, 750 );
    • #38592
      Hoody
      Yes I have the Ultimate Version – Your solution worksbut only affects “Categories” – I also need it for each individual custom Taxnonomy
    • #38596
      Hoody
      Here is a Screenshot for better understanding: https://prnt.sc/logcb6
    • #38598
      Ahh … Ok, we will add this for custom taxonomies as well in next update.
      Thanks for pointing out this.
    • #38829
      Hoody
      Thanks, that would be great!
    • #38849
      WCFM new update already there, now that code will work for custom taxonomies as well.
      Please update and take a look.
    • #38915
      Hoody
      Hey I updateted but I cant seem to find the option for the taxnonomies in Capability-Settings.
      Screenshot: https://prnt.sc/lq1kke
    • #38925
      Hoody
      Ok – In now understand what you did – but that does not solve my problem, it makes it even worse.
      Now you set a global limit for all taxonomies and categories – but in my case i need it individually for eacht taxonomy – please take a look at the screenshot – i made you a mockup: https://prnt.sc/lq265s
      This solution would by far be the best
    • #38928
      Hoody
      Or instead of numbers just make it: Single Select and Multiselct (that would also work) – but as i said it has to be individual for eacht taxonomy
    • #38941
      Ok, I understand your requirement.
      We will add these capability setting in future.
    • #39578
      Hoody
      Hey Guys, any news, when this feature will be implemented?
      Best Regards
    • #39594
      We not yet added this, will add in WCFM U next update.
      I will update you as this will release.
    • #40434
      WCFM Ultimate 5.2.2 version already released and we have added this feature.
      Please update your and take a look.
    • #40461
      Hoody
      Hey guys! Great, it works! Thank you very much for your fantastic support! Now If you mange fto implement the ACF MAP for the Location , i can die happy 🙂
      Keep up the good work!
    • #40465
      You are welcome 🙂
      If you get a chance then add a review for me – https://wordpress.org/support/plugin/wc-multivendor-marketplace/reviews/
  • The topic ‘Possibility to chose between Radio-Buttons and Checkboxes in Vendor-Product Form’ is closed to new replies.
