Pre Sales Question regarding WCFM Ultimate and PDF Vocher use
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace Pre Sales Question regarding WCFM Ultimate and PDF Vocher use
Viewing 11 reply threads
    • #25206
      John
      Hope you can help. I have a query regarding how PDF Vouchers work from a customer communication and vendor perspective in a multi vendor marketplace.
      I am trying to find out how vendors of vouchers get terms and usage info to purchasers via email on purchase.
      Customer buys a voucher and PDF is emailed to them with the additional option of downloading from my account. Is there any mechanism to tell them how to use the voucher and where? Say, a product / voucher specific message in an email to someone purchasing a yoga class voucher from a vendor on a marketplace. I’m thinking like groupon where you get a voucher and the terms, where to use the voucher, what time, etc are contained in the communications from them when you purchase a voucher.
      Would these terms and instructions need to be included in the PDF background image graphic (which seems a bit messy involving site admin / plus other vendors would have access to this info when choosing the style of voucher when creating / adding a product in WCFM), or is there a better way? Like a product custom field the vendor can add to the purchase email, or a plugin like “Woo Custom Emails Per Product” that the vendor can use with WCFM.
      Thanking you in advance,
      John
    • #25332
      Hi John,
      I am not sure which PDF voucher plugin you have tried!
      WCfM works with this – https://codecanyon.net/item/woocommerce-pdf-vouchers-wordpress-plugin/7392046
      And it’s documentation very clear to describe how this works, please go though this once.
    • #25365
      John
      Hi
      Thank you for the info. I am delighted to hear that WCFM Ultimate supports this plugin as it is exactly what I need.
      Regards, J
    • #25366
      You are welcome 🙂
    • #25481
      mail1
      I now have WCFM Ultimate (really like it) and WP PDF Vouchers installed.
      Two issues have arisen:
      1 – When adding a voucher product using WCFMU, I need to set the product as Virtual (no shipping) and Downloadable (so PDF Voucher menu and options appear for vendor to use). When saving the product I get the following error: “Downloadable file is required.” However, my understanding is that the PDF download is generated on a successful purchase. In this instance (PDF Voucher) surely no download needs to be specified. Please advise.
      2 – I notice and extra dropdown option which is out of alignment. What is this dropdown for? Screen shot attached.
      John
    • #25497
      1. Kindly add this code for the resolving this –
      function wcfm_product_fields_custom_downloadable( $downloadable_fields, $product_id, $product_type ) {
      	if( isset( $downloadable_fields['downloadable_files'] ) && isset( $downloadable_fields['downloadable_files']['options'] ) && isset( $downloadable_fields['downloadable_files']['options']['file'] ) ) {
      		unset( $downloadable_fields['downloadable_files']['options']['file']['custom_attributes'] );
      	return $downloadable_fields;
      add_filter( 'wcfm_product_fields_downloadable', 'wcfm_product_fields_custom_downloadable', 20, 3 );
      2. I think it’s visible only for vendors. We will resolve this in next update.
    • #25535
      mail1
      Hi
      Thanks for that, it worked perfectly.
      On testing further I have discovered a few more anomalies:
      1 – If you set the voucher Start Date and End Date using WCFMU as a vendor, save the product, leave the page and return to edit the product the dates reset themselves to the current day (Start Date) and current day plus 1 minute (End Date), thus loosing the dates previously entered (and making the product un-buyable for customers despite being available for sale – gives customer error message similar to – “you cannot purchase products that have expired”) when they try to purchase the product.
      2 – If you set location and location map, save the product, leave the page and return to edit the product the location and map information are lost / not retained.
      3 – I do not know if this is a feature of Ultimate or not, but when you save a product, you get a confirmation message and then the page refreshes to view the product, leaving the WCFMU interface. This adds more page views and clicks to Vendors work flow when adding a number of products. I was not expecting it to function this way, so thought it worth mentioning in case it is not intended.
      Kind regards,
      John
    • #25808
      WCfM 4.1.7 has just released.
      All these has been resolved, kindly update yours and take a look.
    • #26157
      mail1
      Thank you for addressing my observations so quickly. Will download and take a look.
      Kind regards, J
    • #26158
      You are welcome:)
      Please know me if you have any other issues.
    • #26295
      mail1
      I have another few question regarding PDF Vouchers and WCFMU:
      1 – where do / how do vendors mark voucher codes generated by system as redeemed?
      2 – where do / how do vendors check voucher codes?
      As per the voucher code facilities found in:
      Dashboard > WooCommerce > Voucher Codes
      Dashboard > WooCommerce > Check Voucher Codes
      I have looked but cannot find it where to do it, please advise.
      John
    • #26306
      You may setup such pages in site frontend using this short codes – http://wpweb.co.in/documents/woocommerce-pdf-vouchers/pdf-vouchers-setup-docs/#shortcode
      Now, you may add those pages as menu items in WCfM dashboard as well.
  • The topic ‘Pre Sales Question regarding WCFM Ultimate and PDF Vocher use’ is closed to new replies.
