Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › Prechecked virtual radio button, making some settings global
- This topic has 6 replies, 3 voices, and was last updated 7 years, 4 months ago by
Bingal.
- April 3, 2018 at 1:09 pm #21231
Rami
– When adding a new product, Can I make the virtual radio button pre-checked by default as in woocommerce backend adding products?, I mean to have all my products to be virtual by default with out the need of vendors to do so.
-Can I make some settings of the new appointable product to be global, because I don’t want my vendors to set these options by them selves, I am talking here for example making the interval=30 min by default, and the padding time=1 day, and so, if that could be done then I can hide those settings from the vendor dashboard and set them to the suitable selection that I need.
Thanks. - April 3, 2018 at 9:01 pm #21251
Bingal
– Yeah sure, we will do this for you. Just have to add a small code snippet to the site.
– Yeah definitely all these are possible to achieve and even without editing any core files. But this are comes under our paid customisation. Please know me if you are interested in this.
- April 4, 2018 at 12:43 am #21256
Rami
ParticipantThank you for the reply,
– Can you provide me with the code for the virtual radio button to be checked?
– Where I can contact you for discussing the customization I need. - April 4, 2018 at 6:57 am #21257
Here is the custom code for you –
function wcfm_product_manage_fields_general_strict_virtual( $general_fields, $product_id, $product_type ) { if( !$product_id && isset( $general_fields['is_virtual'] ) ) { $general_fields['is_virtual']['dfvalue'] = 'enable'; } return $general_fields; } add_filter( 'wcfm_product_manage_fields_general', 'wcfm_product_manage_fields_general_strict_virtual', 20, 3 );
For custom work please contact directly from here – https://wclovers.com/contact-us/
- April 6, 2018 at 1:51 pm #21396
Is that code works for you?
- April 6, 2018 at 2:22 pm #21403
Rami
ParticipantPerfectly, as usual,
Thank you very much for your help. - April 6, 2018 at 4:19 pm #21416
Bingal
KeymasterThanks for confirming me this 🙂
- The topic ‘Prechecked virtual radio button, making some settings global’ is closed to new replies.
