Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Premmerce Brands for WooCommerce
- This topic has 11 replies, 2 voices, and was last updated 6 years, 2 months ago by
sdel_nevo.
- June 5, 2019 at 12:38 pm #65988
sdel_nevo
ParticipantHi Guys
Before I install Premmerce Brands for WooCommerce, is it compatible?
I know it’s not listed on your compatible addon list, but I could not see the woocommerce brands plugin there either https://woocommerce.com/products/brands/
which would you guys recommend
Steve
- June 6, 2019 at 7:11 pm #66264
Yeah sure, you may use this plugin.
- June 6, 2019 at 7:21 pm #66270
sdel_nevo
ParticipantHi guys
That’s great
Steve
- June 7, 2019 at 9:17 am #66368
sdel_nevo
ParticipantHi guys
i have installed the Premmerce Brands for WooCommerce and everything appears to work ok
the only issues I have is the “Brand” text box in the product page is much wider than the other areas as per the screenshot
and
the widget text does not take the theme setting colour, its shown as a grey colour
do you know how I can change these
I use the flatsome theme
Many thanks
Steve
You must be logged in to view attached files. - June 10, 2019 at 8:16 pm #66826
– This problem is from that brand plugin. Please contact their support for this.
- June 10, 2019 at 9:30 pm #66870
sdel_nevo
ParticipantHi guys
Will get in touch with the developers
Steve
- June 11, 2019 at 5:44 pm #67040
MemberOK, thanks for the update!
- June 11, 2019 at 6:06 pm #67047
sdel_nevo
ParticipantHi guys
I’m getting in touch with the developers in regard to the text colour
But is it possible to change the width of the “brand” text box on the product page as per capture 1
It’s much wider than the other text boxes
Steve
- June 12, 2019 at 6:31 am #67135
Please give me a store URL to check this once!
- June 12, 2019 at 11:41 am #67185
sdel_nevo
ParticipantThis reply has been marked as private. - June 13, 2019 at 7:45 pm #67454
I don’t see any such widget in your site – https://wclovers.com/wp-content/uploads/2019/06/Capture2.jpg
- June 13, 2019 at 7:53 pm #67458
sdel_nevo
ParticipantHi guys
Sorry, I have just disabled that as I was testing “Perfect WooCommerce Brands”
That plugin just works 😀
Sorry to be a pain
Steve
