Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Printing UPS label from front-end
- This topic has 3 replies, 2 voices, and was last updated 5 years, 8 months ago by
- November 1, 2019 at 6:56 pm #90138
ornella
I need to know if the labels can be generated from the WCFM order view.
I can currently do it from wp-admin, but I have it disabled for vendors.I am using:
WCFM Ultimate
https://www.pluginhive.com/product/woocommerce-ups-shipping-plugin-with-print-label/
https://www.pluginhive.com/advanced-shipping-for-woocommerce-multi-vendor-plugin/Thank you
You must be logged in to view attached files. - November 6, 2019 at 4:13 pm #91089
– Can you please contact this plugin support for the purpose, as this integration comes from this plugin. We can not disable this from our end.
- November 6, 2019 at 8:33 pm #91172
ornella
Thank you for your response, I dont want to disable anything. I want to add the views that already are in the back-end admin panel, in front-end vendors panel.
- November 11, 2019 at 6:49 pm #91833
– Sorry, I misunderstood your question. I though you want to disable this vendors.Well, still it will be best to contact that plugin support directly.
- The topic ‘Printing UPS label from front-end’ is closed to new replies.
