Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › problem clic and acces to submenu
- This topic has 8 replies, 3 voices, and was last updated 6 years, 10 months ago by
- September 28, 2018 at 12:50 am #32744
nassim.tamoud
my problem is that the submenu of my admin wcmf dashboard do not open, like all my options after the setting button. Can you tell me more ?Thank you very much <
- September 28, 2018 at 10:58 am #32766
Can you please show me a screenshot for this, which exactly not clickable for you!
- September 28, 2018 at 1:26 pm #32787
nassim.tamoud
Participantthank you for your answer,
it is the submenus as after clicking on “settings” it’s the same thing with the other options, I do not have access to the pages of the submenus (box in red)
Do you know this problem?
You must be logged in to view attached files. - September 28, 2018 at 1:29 pm #32790
Bingal
Can you please check one this in Google chrome browser console?
Is there any JS error in your site or not!Thank you
- September 28, 2018 at 5:01 pm #32799
nassim.tamoud
ParticipantI found that
Uncaught Error: Please call Stripe() with your publishable key. You used an empty string.
at new t (?ver=3.0:1)
at new e (?ver=3.0:1)
at Pa (?ver=3.0:1)
at HTMLDocument.<anonymous> (stripe.js?ver=1.1.1:4)
at i (jquery.js?ver=1.12.4:2)
at Object.fireWith [as resolveWith] (jquery.js?ver=1.12.4:2)
at Function.ready (jquery.js?ver=1.12.4:2)
at HTMLDocument.K (jquery.js?ver=1.12.4:2)
tinymce.js?wp-mce-4800-20180716:5 Uncaught ReferenceError: nivoslider is not defined
at tinymce.js?wp-mce-4800-20180716:5
at Array.<anonymous> (theme.min.js?wp-mce-4800-20180716:1)
at Object.qt [as each] (tinymce.min.js?ver=4800-20180716:2)
at A (theme.min.js?wp-mce-4800-20180716:1)
at L (theme.min.js?wp-mce-4800-20180716:1)
at xe (theme.min.js?wp-mce-4800-20180716:1)
at Pt (theme.min.js?wp-mce-4800-20180716:1)
at Object.renderUI (theme.min.js?wp-mce-4800-20180716:1) - September 29, 2018 at 5:33 am #32824
Thanks for the details.
I understand the problem.
We will resolve this in next update.
- October 1, 2018 at 4:09 am #32935
Kindly update WCFM Marketplace 1.1.2 and please know me is this resolve for you or not!
- October 1, 2018 at 10:39 pm #33011
nassim.tamoud
I solved my problem, I understood with google that my problem was that I did not register my account stripe during the first configuration of wcm. I just started again and my problem was solved.
thank you very much
- October 2, 2018 at 2:48 pm #33053
MemberGreat and thanks for updating me on this 🙂
Well, if you get a chance then please add a review for me – https://wordpress.org/support/plugin/wc-multivendor-marketplace/reviews/
- The topic ‘problem clic and acces to submenu’ is closed to new replies.
