Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Problem to show the plugin in GEO in wp in New Product
- This topic has 11 replies, 4 voices, and was last updated 8 years, 4 months ago by
- June 2, 2017 at 12:00 am #10249
Marcelo Collina
ParticipantI made the purchase of this plugin. I use the WC MarketPlace.
In my portal, to register a product it is necessary to add the address on a map, in the product registration page, via the plugin “GEO in my wp”. With this plugin the Products and new product screen, with vendor vision, does not allow me to include the map. How can I do it? - June 2, 2017 at 2:31 am #10255
Shhiv Narayan
https://wordpress.org/plugins/geo-my-wp/
Are you talking about this plugin, kindly confim?WCFM is not compatible with this addon yet. If you confirm then we will happy to integrate it with WCFM in next update.
- June 2, 2017 at 7:52 am #10258
Shhiv Narayan
We have just go through this plugin and found that it allow to add shortcode of map or form in product short descrption or description.
For doing this they associate a widget to select from.
We don’t have any plan to integrate with this addon very soon as this can be easily done by just copy-past that shortcode within short-description or description box, widget is not neccessary.
- June 2, 2017 at 11:43 am #10259
Marcelo Collina
GuestThis reply has been marked as private. - June 2, 2017 at 11:51 am #10260
Marcelo Collina
GuestBut I need it on all products.
It’s very bad for me or my client to add a shortcode to each product.
How do I make it default? - June 2, 2017 at 5:04 pm #10267
WC Lovers
ModeratorHi Marcelo,
Can you please define how you want to integrate that?
In wp-admin it allows to include a short code in short description or description. Do you want it should work exactly same way in front end as it is in back end?
We will definitely integrate that. But our team is now totally packed up by WCFM 2.3.0 release. So it will take some time, but not more than 15 days.
- June 2, 2017 at 5:14 pm #10268
Marcelo Collina
GuestHello! I would like to integrate like any other info box that is without wp-admin …
If the Geo with wp plugin is installed the location register will appear in the product registration frontend for the Vendor to register. Very close to the Wc booking15 data is a good schedule…If you do this os 15 days, i Will Very happy…
Thank you só much…
- June 2, 2017 at 5:39 pm #10271
WC Lovers
ModeratorHi,
It will not work as other info box as “short code” is essential to be placed with short description or description.
Don’t worry, our team will integrate it by best possible way possible to work with that.
- June 5, 2017 at 3:52 pm #10328
MemberHi Marcelo,
Happy to inform you that our developers has came up with a solution for this.
Please check the attached screenshots for better understanding.
This will available in WCfM 2.3.1Hope this will helpful for you, if you have any further query please feel free to contact us anytime.
Shhiv Narayan
Support WCfMAttachments:
You must be logged in to view attached files. - June 5, 2017 at 4:47 pm #10335
WCfM 2.3.1 has just released, kindly check with that.
- June 6, 2017 at 3:48 am #10388
Marcelo Collina
ParticipantHi, how cool is the improvement that you have made in a very short time …
But I guess that was not the main function I needed …
Look at the attachment, are fields that are provided in the product registration … are not forms that appear for the customer to fill …
Do you think you can integrate this function?
I would be very happy…Attachments:
You must be logged in to view attached files. - June 6, 2017 at 4:48 am #10392
Actually this fields are not coming by default. We have to install “post type” addon and you never mention that before.
I am asking you many time, is that shortcode part is ok for you or not ?
Yes, we can integrate that form. But it is not a normal form, it detects lattitude-longitude from address and doing many map functionality.
We don’t want to integrate such things in our core module.
If we only integrate form fields will be OK for you, kindly confirm.
We can also do that special integration with all Map funtionality, but then it will be a custom solution for you.
Shhiv Narayan
- The topic ‘Problem to show the plugin in GEO in wp in New Product’ is closed to new replies.
