Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › problem with adding & editing products from the dashboard
- This topic has 11 replies, 3 voices, and was last updated 6 years, 5 months ago by
- March 5, 2019 at 11:11 am #51188
bennycohe
Following my earlier email, there is a serious problem with adding and editing products from the dashboard. The problem is present both with front-end and admin product management.The product management is so slow and tedious that it is basically unusable. It is clear that any Vendor that tries to manage and add products will not continue to work with my website.
At present, it is not possible to display products from the Dashboard Products option. The 3 sample test products do not display even though the products have an image uploaded for each product.
As I mentioned in my previous email, this site is under development and it seems that the problems are linked to the large size of categories and sub-categories (10.000 categories so far). This generates a system error. Enclosed is a screen capture of the error message (The problem of slowness began in 1000 categories).
https://1drv.ms/u/s!AlJM7dNlHfVYlZ8ST5Hn-O_F8H0wOQ
Is there a solution to this? It is clear that it is not possible to build a real marketplace vendor website without program stability and reliability.
Thanks BennyAttachments:
You must be logged in to view attached files. - March 5, 2019 at 12:04 pm #51190
takeuchi
ParticipantHello
Thank you for your reply.
Apparently, it seems that a mistake occurred when translating from English to Japanese.It worked normally when wordpress was moved with English version.
I will search what part of translation I failed.
- March 5, 2019 at 7:52 pm #51242
bennycohe
I did not understand the answer, it is irrelevant to my question
Please answer urgently, we can not continue to work on building the site, Not before we know whether there is a creative solution to the problemThanks Benny
- March 6, 2019 at 7:26 am #51294
MemberHi @bennycohe,
That’s right, 10,000 categories is a big factor here. It requires hugh site memory. You are having issue in both areas – frontend and backend!
Now, WCFM has no control over backend product manager!Between, what is your site’s server configuration?
Frankly speaking, WP-WC is not for handling such large dataset. You may even contact WC support for this.
- March 8, 2019 at 9:09 am #51603
bennycohe
1. The data server is now shared, only for the purpose of building the site, In the further we will transfer it to the VPS OR if there is a need for a dedicated server.
2. We have reduced the number of categories to 7000, now you we can see the 3 test products in the dashboard and all working.
3. But The product management dashboard is still slow, This behavior exists right at the beginning even before we started building categories.
4. The support agrees with the dashboard product slowness amendment, Are you going to improve it? If yes When approximately it will be happened?
3. What are the minimum system requirements a hardware server needs, Did you test it before?I have not found any information in your explanations on this subject.
Without this information we will not be able to adapt or build our data hierarchy, it is clear that we are managing other suppliers with different needs. We have all the knowledge for this but we need your support and stability of the plugins.Thanks Benny
- March 8, 2019 at 3:13 pm #51656
Well, we have tested with 1 million products but not such long list of categories.
As I mentioned, WP not even work perfectly with such data, and that’s the reason backend product editor is also slow.
We are looking for a alternate option to load such large data in asynchronous way, hence it will not effect on page load!
- March 9, 2019 at 2:40 pm #51722
bennycohe
I’m glad to hear about your plan, future asynchronous way, In order to illustrate the capabilities of WordPress working with multiple categories.
We are runing another commercial site (beautypediya.com, non-market place), with 3500 categories + product filter + 75 different plugins installed + A lot of products, VPS server, very fast commercial site knowenhost (hosting company), I’m trying to say here that the system works fast, and without problems.
This is the main reason we strive to grow to a marketplace, because the number of our suppliers is growing as well as the products.
Do you have an estimate time of when this task will be completed? We have no problem if it takes time, Just want to trust and get stability in your system.
It is very important for us to know, so we can plan our work order, we are very serious in our request. And want to rely on your system. We love your way of thinking but the most important part is the Slowness product management.
Forgive me for bothering, I do it out of caring for the mission, we strive for perfection at work
Thank you Benny
- March 10, 2019 at 6:07 am #51804
We have already implemented this.
Please update WCFM 5.4.4 and install this addon – https://drive.google.com/file/d/1znUbF22LEaqQjZQUKj6lHBBodGaZ7yiQ/view?usp=sharing
- March 10, 2019 at 3:19 pm #51854
bennycohe
1. Thanks to the update 5.4.4, Dashboard / products link working good and fast, I am happy.
2. But, Add OR edit product from the front end OR back end still slow.
3. I have installed the “WCFM Category Hierarchy 1.0.0” about 2 month ago, you send it to me and it is wonderful. Are this the same plugin or instead OR new one (new version)On another subject:
What is the best way to translate the plugins?
1. mo and po files
2. Install WPML
Thanks Benny - March 10, 2019 at 6:05 pm #51879
It’s totally new version and works differently, please install this and check.
Well, I can not assure Product edit backed speed, but this will change frontend speed definitely.
Please try and know me!
- March 11, 2019 at 6:53 pm #52117
bennycohe
Amazing, really great, Now I really enjoy working and editing products, The transition is very fast in editing products.
Viewing the product from editing mode to the front end store is very quick, And editing a product from the front end store to the editing mode is also very quick.Edit OR add new product is also fast, Now it working like expected.
Thank you allBenny
- March 12, 2019 at 4:54 am #52185
MemberThat’s really great, thanks for the update.
Have a great day 🙂
- The topic ‘problem with adding & editing products from the dashboard’ is closed to new replies.
