00Day 05Hr 31Min 29Sec
Problem with default search redious bar
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Problem with default search redious bar
Viewing 1 reply thread
    • #125448
      justboloindia
      Hi
      By default the search redious bar is at 2km. Want to set it till maximum range set on store manager. We are loosing customer due to this reason. How to do that.
    • #125455
      For this you need to adjust “Maximum Radius to Search” (From WCFM-dashboard->Settings->Geo Location)
      And then add below code in your theme’s functions.php
      add_filter('wcfmmp_radius_filter_start_distance',function($start_distance){
      	return 1;
      We have already replied you https://wclovers.com/forums/topic/how-to-change-the-default-search-radius-google-map/ in this thread.
  • The topic ‘Problem with default search redious bar’ is closed to new replies.
