Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Problem with message board WCFM ultimate
- This topic has 16 replies, 4 voices, and was last updated 7 years, 10 months ago by
Shhiv Narayan.
- October 11, 2017 at 7:19 am #14208
- October 11, 2017 at 8:04 am #14211
WCfM Forum
Really sorry for the inconveniences and thanks for reaching us.
Just give me a small info – which multi-vendor plugin you are using?
Just relax, we will fix this and update WCfM within 2 days.
- October 13, 2017 at 6:12 am #14302
javier
ParticipantHi Hi.
I am using wc vendors pro.
https://www.wcvendors.com/I also encountered a problem when I wanted to modify or create a product, since the changes that were made were not saved.
Help me please. - October 13, 2017 at 12:27 pm #14318
WCfM Forum
I have just checked with WC Vendors and their is no issue with message sending. You may even check in our demo site as well.
This is something else, as now your products also not saved so some JavaScript issue is their definitely.
Can you please check browser console, is there any errors or not?
Best will be, if you are comfortable enough to give me a demo Vendor access to check the errors.
- October 14, 2017 at 7:10 pm #14349
javier
Participanthello friends
I’ll give you access to my test site.
Thanks - October 14, 2017 at 7:11 pm #14350
javier
ParticipantThis reply has been marked as private. - October 14, 2017 at 7:38 pm #14351
WCfM Forum
Really thanks for that.
I am just looking into this.
Thanks for your cooperation.
Shhiv
- October 14, 2017 at 8:15 pm #14352
javier
ParticipantThis reply has been marked as private. - October 15, 2017 at 6:54 am #14353
Shhiv Narayan
I have just debug the issue and all this are coming because of “Fast Velocity Minify”
I have just disabled a setting of it so now things are working fine.
Also looking for alternate solution for this.
PFA, thousands of errors and all are from that particular plugin.
Why you are going with plugin like “Autoptimize”? Doing the same thing but much safer and stable!!
You must be logged in to view attached files. - October 17, 2017 at 12:04 am #14431
javier
ParticipantHi. thanks for your time.
So you suggest that I turn off “Fast Velocity Minify” and instead use “Autoptimize”? - October 17, 2017 at 3:45 am #14440
Shhiv Narayan
MemberNO, please wait a bit till WCFM next update.
We will add support of “Fast Velocity Minify” in next update.
- October 17, 2017 at 7:22 am #14459
- October 17, 2017 at 7:24 am #14461
javier
ParticipantThis reply has been marked as private. - October 17, 2017 at 8:00 pm #14470
Sorry for a bit delayed response.
I have just checked that and I think it’s only because you have deleted some WooCommerce Orders manually!!
Now this is very dangerous for a marketplace site, lots off issues will come and most importantly all sales report will show you wrong data.
Mark orders cancel or failed but please don’t delete, even may kept in trash.
Anyway, we have added some fix for this in WCFM coming version so that it will not throws error for such cases.
- October 17, 2017 at 11:50 pm #14508
WCFM 3.2.2 has just released and we have added exclusive support for WP cache and minify plugins.
Be sure, you have to purge existing cache and JS/CSS minification after updating the plugin.
Your fatal error also taken care off.
Please know us is everything works perfectly for you or not!!
- October 18, 2017 at 12:45 am #14513
javier
Participantthank you very much, the attention is great and the product too. Without a doubt the best purchase!!
- October 18, 2017 at 4:45 am #14514
Shhiv Narayan
MemberThank you thank you ..
We are just trying our best and such appreciation really really motivating.
It will be more pleasure for us if you say something here –
https://wordpress.org/plugins/wc-frontend-manager/Please feel free to reach us anytime for any assistance.
- The topic ‘Problem with message board WCFM ultimate’ is closed to new replies.
