Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Problem with Woocommerce Simple Auctions settings
- This topic has 10 replies, 2 voices, and was last updated 6 years, 9 months ago by
- October 16, 2018 at 7:45 pm #34145
WWW
ParticipantI honestly do not know if the problem is related to wcfm marketplace or rehub theme i use. Please advice.
I have an issue with the following auction setting:
“Do not mix auctions and regular products on shop page. Just show auctions on the auction page (auctions base page)”
I have set a separate auctions page and auctions do appear on that page just fine.
But:
Each time I sort something with any filter, all the regular type products appear on the result and auction type products disappear from the result.
Do you have any idea why this may be happening? If you need more info, please ask.Also when refreshing the options page later, the check in the check box of this option disappears.
- October 17, 2018 at 2:01 pm #34190
Can you do a test?
Uninstall all plugins except WooCommerce and Simple Auction Plugin.Actually, I want to be sure it’s not an issue from Simple Auction plugin!
- October 17, 2018 at 4:07 pm #34208
WWW
ParticipantHi and thanks for response.
I found the plugin causing the issue. Its https://themify.me/themify-product-filter
As soon as I deactivated it, everything started working as normal.
Thats a shame because its an awesome product filtering plugin! - October 17, 2018 at 4:14 pm #34209
Ahh .. please contact that plugin author and hopefully they will resolve this soon.
Between, thanks for updating details here, hopefully helpful for others 🙂
- October 17, 2018 at 6:19 pm #34234
WWW
ParticipantActually, no to my last post.
The problem still exists. I am trying to figure out what is causing this. Debuging plugin shows no errors.
- October 17, 2018 at 7:12 pm #34241
WWW
ParticipantOK, This took some time, but finally i know what is causing this.
It’s the
WooCommerce Frontend Manager – Ultimate
When I disabled it. Everything started working normally. Even with the https://themify.me/themify-product-filter which I thought was causing the problem earlier.The filtering is causing all products to appear on the page, but it is not causing the “Do not mix auctions and regular products on shop page. Just show auctions on the auction page (auctions base page)” option to become inactive and buggy.
I quess the reason why filtering is causing all products to appear instead of just auctions or regular products is because I have a single shared categories for both types and the themify filter does not take in to account that the page is signed either the auctions only or the regular products only.
When i disable both the themify filter and the WCFM-Ultimate, then both pages work normally, but I have no advanced filtering available.Please investigate, why the WCFM-Ultimate is causing this issue for me.
- October 18, 2018 at 4:54 pm #34323
MemberUmmm .. we are checking this.
Thanks for all the details.
- October 18, 2018 at 7:20 pm #34330
WWW
ParticipantCan you confirm that you can reproduce this bug on your test site?
- October 20, 2018 at 3:50 pm #34431
Sorry for a bit delayed update.
We are able to generate the problem, will resolve this in next update.
- October 20, 2018 at 6:32 pm #34445
WWW
ParticipantGood to hear that this will be fixed soon!
Thanks! - October 24, 2018 at 3:28 pm #34762
WCFM Ultimate new version has just released and this issue has been resolved.
- The topic ‘Problem with Woocommerce Simple Auctions settings’ is closed to new replies.
