Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Problems to translate for portuguese
- This topic has 6 replies, 3 voices, and was last updated 8 years, 2 months ago by
Shhiv Narayan.
- June 2, 2017 at 1:22 am #10252
Marcelo Collina
ParticipantHow can i translate the plugins?
- June 2, 2017 at 2:27 am #10254
Shhiv Narayan
You may use Loco Translate plugin to translate the plugins in any language easily.
- June 2, 2017 at 11:54 am #10261
Marcelo Collina
GuestUm already use this plugin…but i have 3 plugins for the same thing… WC Marketplace, frontend and Frontend ultimate…
And no one is working - June 2, 2017 at 12:54 pm #10262
Shhiv Narayan
Ohk, let us check once again.
Some of our customers already told us that they are translating using Loco Translate so I am suggesting you to do so.
If there is something missing from our side then definitely fix by next update.
- June 2, 2017 at 5:20 pm #10270
Marcelo Collina
GuestBut whats plugin I need tô translate for change the frontend?
– WC Marketplace
– WC Frontend
– WC Frontend ultimate ???? - June 2, 2017 at 5:57 pm #10272
WC Lovers
ModeratorHi Marcelo,
From WCFM 2.3.0 you can able to translate WCFM using Loco translate.
I can’t say anything about WC Marketplace in this case.Thank You
- June 3, 2017 at 4:48 am #10277
Shhiv Narayan
Hope now you can translate both the plugins using Loco translate.
Shhiv
- The topic ‘Problems to translate for portuguese’ is closed to new replies.
