Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Problems with some translations
- This topic has 7 replies, 4 voices, and was last updated 8 years, 4 months ago by
Shhiv Narayan.
- November 20, 2017 at 7:52 am #15902
- November 20, 2017 at 7:53 am #15907
- November 21, 2017 at 5:58 am #15918
Thanks for pointing all this and I will definitely look into these.
Please sync your translation file once.Thank You
- November 23, 2017 at 4:55 am #15991
- November 23, 2017 at 5:22 am #15994
All these strings are there for translation new update.
You have to update your existing translation file with latest code. But as I found you have generated translation file from “Spanish(Spanish)” translation, and not from actual plugin translation template.
So first you have to update “Spanish(Spanish)” translation file with latest template and then “Spanish(Mexico)”.
I already did that in my system and all strings are there, PFA for reference.
If you failed to do so then please know me, I will send you updated “Spanish(Mexico)” translation files to you.
You must be logged in to view attached files. - November 23, 2017 at 5:51 am #15999
- November 23, 2017 at 7:33 am #16001
Simha
You are right, we have missed that.
Thanks for knowing that we have missed “Thank You” 😀
Will add in next update be sure.
- November 28, 2017 at 12:12 am #16237
Shhiv Narayan
MemberIt has been resolved with the WCFM 3.3.2 update.
- The topic ‘Problems with some translations’ is closed to new replies.
