Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Problen with intehration with Woocommerce PDF Vouchers
- This topic has 9 replies, 3 voices, and was last updated 7 years, 8 months ago by
- March 31, 2018 at 12:20 pm #21125
admin15
It seems that the option to make a product Downloadable and then Voucherable is only applied to the simple type product through the vendor dashboard.
Shouldn’t it be available for all prosuct types? At least variable and bookable.
- April 1, 2018 at 5:08 am #21149
For a product to be a voucher it should be downloadable, it’s default requirement from WC PDF Voucher plugin.
Voucher can be work for variable product and we will add support for that as well.
But not sure is it work for Bookable product or not, will check and know you.
- April 1, 2018 at 10:23 am #21159
admin15
ParticipantHi and thanks for responding.
When will variable product type be integrated with pdf vouchers?
Also i need to kbow about bookables as wel.
- April 1, 2018 at 8:54 pm #21166
Bingal
Our team is already on variable part and it will be there in WCFM 4.0.3
I will check Bookable and update you.
- April 14, 2018 at 4:55 am #21771
admin15
i hope you are doing well.
1. I am currently on version 4.0.5 and i do not see PDF voucher functionality being applied on variable products.
2. In vendor dashboard there is no ability to click on a button and generate voucher codes with prefix/separator/suffix as the original plugin offers.
3. I am also waiting for a response from you regarding bookable products. Will the functionality of PDF Vouchers be available for this product type as well?If so when?
4. I would also like to know if you have dedicated programmers that are available to work on you plugin in order to modify/add functionality as per our requests/needs?
Thank you in advance
- April 14, 2018 at 9:21 am #21781
We are still working on PDF vouchers Variable and Bookable product part. It will be there is next WCfM update,be sure.
“I would also like to know if you have dedicated programmers that are available to work on you plugin in order to modify/add functionality as per our requests/needs?”
– Do you mean for custom works? We are implementing most of the things as per our users recommendation, and also everything has a priority depending upon no of request for a feature.Thank You
- April 15, 2018 at 4:27 pm #21853
admin15
ParticipantΗi,
Thanks for your response.
You forgot to answer my following question:
- April 18, 2018 at 7:07 pm #22019
admin15
Any response regarding the below:
1. In vendor dashboard there is no ability to click on a button and generate voucher codes with prefix/separator/suffix as the original plugin offers.
2. When will the next update be available with the integration between woocommerce pdf vouchers and variable – booking product types ?
- April 19, 2018 at 4:42 am #22024
WCfM 4.0.6 has just released.
Kindly update yours and take a look both these features implemented.
- The topic ‘Problen with intehration with Woocommerce PDF Vouchers’ is closed to new replies.
