WCFM Anniversary
We've turned 8! Celebrate with us and take away upto 25% OFF on WCFM Addons.
01Day 00Hr 17Min 09Sec
WCFM Anniversary
Product Acrhive Page (shop) not appearing
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Product Acrhive Page (shop) not appearing
Viewing 11 reply threads
    • #123491
      harlanz10
      Hello friend.
      I am using the WCFM plugin in my website. Which is using an Organica Theme (not storefront).
      The problem is that the shop page is not displaying as I would like.
      I want it to look like this:
      https://wcfmmp.wcfmdemos.com/?v=dc22bee690b7 (with the geolocation map and filters at the sidebar)
      But instead it is looking like this:
      https://autotienda.pe/shop/
      Can you help me to set up the shop page that I am requesting? How should I do it? I cant find the widget or shotcode that could help.
      Attached are the active plugins that I have.
    • #123523
      Keymaster
      From inside WCFM admin dashboard go to Settings >> Geo Location and enable “Product List Radius Search” option. This will bring the map and filters in your shop page.
      Note you will also need to setup Map Library option from here. If you choose Map library as Google Map then you will need to enter your Google Map API Key.
      Next we’ll setup the filters on the sidebar. As I can see currently you are using full-screen template. So first choose a template with a left sidebar from your theme. Then go to wp-admin >> Appearance >> Widgets and from there add the following to your default sidebar
      – Product Search widget
      – Filter Products by Price
      – Marketplace: Best Selling Vendors
      – Marketplace: Top Rated Vendors
      – Vendor Store: Top Rated Products
      And, that’s it! 🙂
    • #123530
      harlanz10
      Thank you very much!! The first step for adding the map worked.
      As you recommended, I switchet to a side bar template (see image “Settings side bar” attached), but I’m still having trouble with adding the sidebar. I’m trying to add the widget and it seems to be that there is only a “Top Content” bar where the editor lets me add the widgets. (see “Top Content Bar only” img attached).
      Can you help me please with that last step?
      Thanks in advance!
    • #123654
      Keymaster
      Go to wp-admin >> Appearance >> Widgets and from there add your widgets to your sidebar.
    • #123726
      harlanz10
      I already tried that at first moment but sidebar stills not showing.
      That’s why I went to Appearance/personalize and from there, it says that the template has only space for witgeds in top bar. How should I activate the sidebar instead of a topbar?
    • #123731
      Keymaster
      That depend upon the theme. You could check the theme documentation or contact the theme author.
      Let me know how this goes.
    • #123972
      harlanz10
      Ok Friend. I will let you know. Meanwhile. Can you help me with this problem?:
      When I set my location and then I use the radius filter (in shop list or product list page), it always shows no results. Even when the Radius selected is 1km.
      Can you help me please? http://www.autotienda.pe
    • #124317
      Keymaster
      Would you be comfortable sharing a temporary backend access of your site, along with site url, to debug this further?
      When sharing the access, please don’t forget to mark the reply as private.
    • #124326
      harlanz10
    • #124380
      Keymaster
      Please check it’s working now.
    • #124382
      harlanz10
      Yes it it’s working! Thanks!! Can you explain me please what was the problem? I would need it.
      Thank you very much for your time!
    • #124386
      Keymaster
      I just saved the vendor address again. So there might be some issue with the address of those vendors.
  • The topic ‘Product Acrhive Page (shop) not appearing’ is closed to new replies.
