Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product Attributes not creating product variation
- This topic has 4 replies, 2 voices, and was last updated 6 years ago by
Sarmistha Chakraborty.
- June 1, 2020 at 8:05 pm #137349
akshat
ParticipantHi!
I created a store and added a product on it. I changed the product to variable product and selected existing attributes for the latter (and added the required attributes to that), i ticked the “Used for Variations” as well but it still shows “Before you can add a variation you need to add some variation attributes on the Attributes tab.”.
There is also a javascript error:
Uncaught SyntaxError: Unexpected token in JSON at position 43 at JSON.parse (<anonymous>) at Function.n.parseJSON (jquery.js?ver=1.12.4-wp:4) at Function.a.parseJSON (jquery-migrate.min.js?ver=1.4.1:2) at Object.success (wcfm-script-products-manage.js?ver=6.5.0:816) at i (jquery.js?ver=1.12.4-wp:2) at Object.fireWith [as resolveWith] (jquery.js?ver=1.12.4-wp:2) at x (jquery.js?ver=1.12.4-wp:4) at XMLHttpRequest.c (jquery.js?ver=1.12.4-wp:4)Please help.
- June 2, 2020 at 12:14 pm #137592
May this is happening due to some plugin conflict. Kindly disable all other plugins except WooCommerce and WCFM plugins(updated version). Then check once again.
Let us know how it goes.
Please be advised to check the attributes options are turn-on or not. (PFA)Thanks!
You must be logged in to view attached files. - June 2, 2020 at 12:53 pm #137630
akshat
ParticipantHello Keymaster,
I tried your suggested edits, but the same thing repeats, I disabled every other plugin and enabled only the WCFM plugins and WooCommerce. No luck solving that. Please help.
Thanks & Regards.
- June 2, 2020 at 12:59 pm #137636
akshat
ParticipantHi Team, I just noticed that if i double/triple click on variations then it starts showing for some reason. Please help me why is this happening. Thanks
- June 3, 2020 at 2:04 pm #137968
The javascript error you have posted #137349 reply, after deactivating others plugin still you have the same error?
You can provide us the site access with URL, then we can check the issue in your site.(Set as private reply)Thanks.
- The topic ‘Product Attributes not creating product variation’ is closed to new replies.
