Product availability based on vendor postcode
Viewing 2 reply threads
    • #127834
      arshad.yusofff
      Hi, is it possible to set vendor location availability to certain postcode, so that when the customer search in the map filter, only the product within the vendor postcode will appear.
    • #129984
      delwyn
      Hey there, i’m looking for similar solution, have you managed to found a solution for this?
    • #129986
      delwyn
      appreciate if you’d let me know if you do 🙂
