Product Custom Field
Viewing 1 reply thread
    • #30511
      Jordil
      I’ve created a Custom Fiels in “Seetings – Product Custom Field” this field has been created before with “Advanced Custom Fileds”. All it’s ok but I can’t, but in the “Visibility” filed I have no options of visibility location, its only showing me “Do not show”. Do you know the solution.
      Great plug in!!!
      Thanks a lot
    • #30806
      Hi Jordil,
      Well, visibility options are part of WCFM Ultimate – https://ibb.co/k4Z7Xz
      So you just have to upgrade your WCFM.
  • The topic ‘Product Custom Field’ is closed to new replies.
