product custom field
Viewing 1 reply thread
    • #80740
      wpxpert
      do you have custom code for follwoing request.
      1. can you add multi select field in product custom field section.
      2. I need checkbox group field in product custom field section.
    • #80824
      You are using ACF, right?
      We will add multi-select field support in next update.
      ACF Checkbox group field is already supported.
