Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › product custom field – text formatting
- This topic has 7 replies, 3 voices, and was last updated 5 years, 12 months ago by
- August 14, 2019 at 12:13 pm #76586
kaloomee
ParticipantHI
Created a new field in ‘product custom field’
But when vendor enters text in the teaxt area field the text is not formatted (No line break)
I have this feild set for vendors to be able to add T&C’s particular to that product so if there is a long T&C (paragrpahs etc) then display is not goodPlease make this Custom field text area formatted
Regards
Kaloomee - August 20, 2019 at 6:48 am #77419
We will definitely take care of this in next update.
- August 20, 2019 at 8:56 am #77479
kaloomee
ParticipantMost excellent, Thank you,
Great support as evver - August 22, 2019 at 3:09 pm #77787
MemberYou are welcome 🙂
- August 27, 2019 at 8:14 am #78474
understandingisthebest
both admin and vendors are not been able to view and add new product from the Store Manager Products Dashboard ( frontend)
- August 30, 2019 at 4:52 am #79114
What’s happening when you are trying to add new product?
Also check using Google Chrome Browser console, is any JavaScript error happening to your site or not!
- August 31, 2019 at 9:36 am #79307
Participant1.) The below errors are the errors generated by the WooCommerce -> Status -> Logs -> fatal_erros log
2019-08-27T09:46:34+00:00 CRITICAL Cannot redeclare getDirList() (previously declared in /home/orisunmart/goodieslite.com/wp-content/themes/tokoo/inc/redux-framework/class.theme-modules.php:25) in /home/orisunmart/goodieslite.com/wp-content/themes/tokoo/inc/ocdi/class.theme-modules.php on line 41
2019-08-27T10:38:08+00:00 CRITICAL require_once(): Failed opening required ‘helpers/class-wcfmu-dependencies.php’ (include_path=’.:/opt/cpanel/ea-php56/root/usr/share/pear’) in /home/orisunmart/goodieslite.com/wp-content/plugins/wc-frontend-manager-ultimate/wc_frontend_manager_ultimate.php on line 21
2019-08-27T11:49:39+00:00 CRITICAL Call to undefined method WC_Product_Booking::get_enable_range_picker() in /home/orisunmart/goodieslite.com/wp-content/plugins/wc-frontend-manager/core/class-wcfm-wcbookings.php on line 333
Please, how do I fix these errors?
2.) Have check in Google Chrome Browser colsole, there is no JavaScript error happening.
3.) The below attached files are what is happening on the WooCommerce Frontend Manager product dashboard.
Please study the attached files very well.
You must be logged in to view attached files. - September 2, 2019 at 12:54 pm #79617
MemberI have already fix this for you.
It was due to hosting migration.
- The topic ‘product custom field – text formatting’ is closed to new replies.
