Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product exporting
- This topic has 5 replies, 3 voices, and was last updated 7 years, 7 months ago by
Bingal.
- April 27, 2018 at 5:31 pm #22448
majdkouwefi
ParticipantHi WC Lover team,
1- When I’m exporting the product there are no values for the fields!
2- Now I’m having 2 logouts on my account page after upgrading to Ultimate version!Could you please look at my problems and reply me as soon as possible.
Thanks in advance,
- April 27, 2018 at 8:20 pm #22454
1. Are you exporting as Vendor or Admin? If vendor then please scroll down and check.
2. Can you please know which theme you are using in? Possibly you can manage this item list from theme setting panel, if so then delete “Logout” from there.Thank You
- April 27, 2018 at 8:32 pm #22455
majdkouwefi
Yes, I found the data thank you, but it does not look organized at all. the data is not related to the column I mean the data for the name of the product there are numbers and for the images there are numbers, it is a really messy.
Thank you,
- April 27, 2018 at 8:34 pm #22457
Bingal
Kindly set your excel character encoding to UTF-8
- April 27, 2018 at 11:02 pm #22471
majdkouwefi
ParticipantHi Bingal,
Thank you it works now.
- April 27, 2018 at 11:06 pm #22472
Bingal
KeymasterWelcome 🙂
- The topic ‘Product exporting’ is closed to new replies.
