Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Product Limit
- This topic has 3 replies, 3 voices, and was last updated 7 years, 3 months ago by
- June 16, 2019 at 12:44 pm #67958
kml_ozer
ParticipantHello.
How to set a membership-specific product limit.Although I have set a product limit (eg 10) from the membership properties, the product limit appears to be unlimited.
Do I need to make another adjustment?
I have a question outside the topic. Are you considering adding the XML product installation option for vendors? - June 16, 2019 at 1:49 pm #67967
sdel_nevo
ParticipantHi kml_ozer
have you set up capacity for the group?
if you are using the ultimate plugin, you can create a group and give it 10 as the product limit, and assign this group to your membership plan
if you do not have the ultimate plugin, I believe that you can still achieve what you want by setting “capability” to 10 products, this method would mean that all your membership plans would be limited to 10
Steve
- June 16, 2019 at 3:48 pm #67973
kml_ozer
ParticipantI am using WCFM ulimate. I don’t have GROUP & STAFF plugin. I want to apply 3 membership plans and different product limits for each plan. I understand I can’t do this without the GROUP & STAFF plugin. Thank you for your answer.
- June 18, 2019 at 12:52 pm #68337
MemberI want to apply 3 membership plans and different product limits for each plan. I understand I can’t do this without the GROUP & STAFF plugin.
– Yeah right!
- The topic ‘Product Limit’ is closed to new replies.
