Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product limit not work
- This topic has 6 replies, 2 voices, and was last updated 7 years, 9 months ago by
nnapus.
- June 10, 2018 at 12:26 pm #24620
nnapus
ParticipantThe function of advanced capability controller for product limit does not work.
I’m not sure, what’s happening. Please help me solve this issue.
Now all my vendors can create up to 10 items equally for every group or every membership level.My website information: WCfM-Ultimate, WCfM-GS, WCfM-Membership
- June 10, 2018 at 2:47 pm #24628
Thanks for all the details.
Can you check one setting please?
WCfM Admin Settings -> Verification -> there is a product limit for non-verified members
Please be sure you didn’t set 10 there anytime, may be by mistake.
- June 10, 2018 at 5:19 pm #24636
nnapus
ParticipantOk, You are right about the limitation for non-verified members. For the issue, I have edited already.
Now I find a new issue that related to the original problem.
That is in the verification menu tab; After uploading the photo to the media library when I select the image. It does not show up on the verification page.The conclusion is the vendors were unable to verify the identity via the upload button.
Thank you.
- June 10, 2018 at 6:54 pm #24641
From the screenshots it seems to me, there has some JavaScript errors in the page.
Can you please check this from Google Chrome browser console?
If you have any caching plugin then please clear old cache once as well.
- June 11, 2018 at 7:11 am #24675
nnapus
ParticipantI found something in the Google Chrome browser console;
1. Some menu tab lost.
2. Warning and Errors, please see the attached file#verify-4.Note: My website used WP Fastest Cache Plugin.
- June 12, 2018 at 12:43 pm #24729
This issue is due to “Thai” character.
Will add support of this in next update.
Thanks for your cooperation.
- June 13, 2018 at 6:11 pm #24766
nnapus
ParticipantThank you very much.
- The topic ‘Product limit not work’ is closed to new replies.
