Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Product Limit only for the Product Types
- This topic has 1 reply, 2 voices, and was last updated 5 years, 6 months ago by
- February 10, 2020 at 6:56 am #106352
Sarah
ParticipantHi, how can I make it so that each vendor is limited to upload a maximum of 50 different products? I have set the Product Limit to 50 under the Capabilities but that includes the quantity of each product e.g. one of my vendors has only 5 different products but has put in stock quantities of 10 for each and she can not upload anymore products – it is showing she has 50! I would like my vendors to only be able to upload 50 different products which can have as much quantities in stock of each as they would like. Thank you.
- February 10, 2020 at 12:36 pm #106375
KeymasterHello,
Thanks for reaching to us.
The ‘Product Limit’ settings under Capability works exactly the way you want i.e. it take into account total number of products. Quantity is not come into play here. So if you set Product limit 50, then each of your vendors should be able to upload 50 different products irrespective of their quantity.
Please check your settings once again.
