Clicking the map under the product location opens the Google map on a new tab but does not highlight the store name with the red map pointer. PFA image. The same issue is also there if we add store location using a widget on the sidebar.
However, if we click on the blue map marker on the seller’s store, beside the store logo, phone number, email id… that also launches a new tab with the Google map, and this time, it shows the store name on Google map with the red map marker. Navigation can be initiated easily here.
How to get the same map result, when a visitor clicks on a product location map and also the map from the widget on the sidebar? It should show vendors store name with the red map marker on Google map.
You must be
logged in to view attached files.
