Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product Location in "Add Product Form"
- This topic has 14 replies, 3 voices, and was last updated 6 years, 6 months ago by
jan.
- December 12, 2018 at 4:02 pm #39852
Hoody
GuestHey there,
If Im using the “Geo My WP” – Plugin, I have the possibilitiy to ad a Location to Product in the vendor form. (–> https://prnt.sc/lu2wog)
If i deactivate GeoMyWP the option to add a location is no longer available.Here is my Question: Is it possible to have the same Location-Option with the ACF-Maps-Field instead of using GeoMyWp?
- December 12, 2018 at 4:15 pm #39853
Ok, we will take a look at ACF Map field.
But I don’t think ACF Map field is not that much feature enrich as GEO My WP.
- December 13, 2018 at 4:52 pm #39987
jan
ParticipantFunny, I just wanted to ask the same question:
jQuery Google map location selector don’t work for me when I use advanced custom fields with WCFM. It just doesn’t show in the Tabs. Is it planned to support this in future?
Also, the Append/Prepend values don’t show for number fields. - December 14, 2018 at 12:05 am #39996
jan
ParticipantFYI:
Date Picker field type throws an error as well:
Notice: Undefined index: date_format in […]/wp-content/plugins/wc-frontend-manager-ultimate/views/thirdparty/wcfmu-view-acf-products-manage.php on line 192 - December 14, 2018 at 5:00 am #40007
Yeah, that’s right -> WCFM not yet have support of ACF Map field, will add very soon.
You may use GEO MY WP for the purpose.
We are checking date picker issue.
- December 14, 2018 at 9:01 am #40013
jan
ParticipantAlright, thanks. I just wanted to avoid another plugin and manually coding it into my custom post type. With ACF, it would have been in the right place already 🙂
Besides the datepicker issue , also the size values (rows for textarea for example) and the Append/Prepend values are ignored.Thanks a lot for your great support!
- December 15, 2018 at 5:56 am #40065
You are welcome.
Don’t worry, we will take care of this in next update.
Have a great weekend 🙂
- December 17, 2018 at 1:41 pm #40252
jan
just recognized another issue which is a bit worse than the others:
For ACF select fields, always the selected number is saved, not the value itself.
Example: ACF select field has selectable values 2018, 2019, 2020, 2021. In store manager, I select 2019. In the database, it’s saved as “2”, as I have selected the second value.
If I edit the product without WCFM Ultimate in WooCommerce directly, it’s saved correctly as “2019”.I could probably get around this with another query, but this has several other ugly impacts besides just a wrong return value: Switching between WCMF and native product editing loads wrong values, and adding/removing another possible ACF value for the select would change all saved values.
Thanks & Regards!
- December 19, 2018 at 9:40 am #40368
jan
ParticipantIn v5.2.5 Changelog, it says:
Enhance – ACF and ACF Pro map field support added
Enhance – ACF time and date-time field type support added
Fixed – ACF date picker field issue resolved
Fixed – ACF select field index issue resolvedUnfortunately, I cannot confirm any of these changes/fixes :-/
Am I missing something or is it because there is no new according Ultimate version yet?Nevertheless, appreciate you’re working on it! 🙂
Have a nice day!
- December 19, 2018 at 4:16 pm #40385
jan
ParticipantSorry guys, I just found another one, similiar to the post above from Dec 17:
ACF image fields get saved to the DB with their URL instead of their ID. ACF itself stores the images by ID
Result: value returned wrong, preview image not displayed neither in native ACF nor in store manager, not compatible to native ACF view. - December 20, 2018 at 10:50 am #40445
“Unfortunately, I cannot confirm any of these changes/fixes :-/”
– Do you have updated WCFM Ultimate to latest version 5.2.2 ?
Still not getting this?
In fact we have resolved select box issue as well in this latest update.We will check image field issue.
- December 20, 2018 at 12:48 pm #40481
jan
ParticipantNobody knows why Ultimate update was not displayed but the other two were. I got the update now, two days later. WordPress magic 😀
Select field issues and datepicker issues are resolved – these were the most important ones. Awesome! 🙂
Append/Prepend hints are not shown yet.
Maps, I’m still testing, currently the field is not displaying yet.Thanks for looking into the image issue as well!
Very nice to see progress so fast! - January 7, 2019 at 11:11 am #42508
jan
ParticipantHi there 🙂
After all the updates the last weeks (amazing!) I tested again, but it seems the left over ACF issues have not been addresses, have they?
– ACF image fields unusable
– Append/Prepend info not displayed
– Maps field not displayedIs this on your agenda or do I need to find workarounds?
Thanks and have a nice day! - January 8, 2019 at 5:09 am #42592
What is your WCFM Ultimate version right now?
– We have added support this around 1 month agoWill resolve others very soon as well.
- January 8, 2019 at 7:54 pm #42722
jan
ParticipantWhen posting this I was on 5.2.6 yesterday, now I am on 5.2.7.
Both versions do not show the maps field, just the heading. Tested with products and articles. Other fields are displayed OK.Thanks for checking 🙂
- The topic ‘Product Location in "Add Product Form"’ is closed to new replies.
