Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › PRODUCT PERSONALIZED FIELDS
- This topic has 4 replies, 2 voices, and was last updated 5 years, 11 months ago by
Gregorio.
- April 27, 2020 at 12:08 pm #123565
Gregorio
ParticipantHi, I have implemented two personalized fields for product, both as groups. The first area contains text type fields only, the second check box type only.
Both areas are available in the vendor manager panel, but text inserted in the first area is not saved and not show on the webpage.Attachments:
You must be logged in to view attached files. - April 27, 2020 at 12:27 pm #123575
Sarmistha Chakraborty
Well, this is possibly due to “field name” you have used for creating custom fields.Kindly be sure “field name” does not have any spaces and special characters.
Ref:https://wclovers.com/forums/topic/custom-fields-not-displaying-on-product-page/
- April 27, 2020 at 2:10 pm #123614
- April 27, 2020 at 2:50 pm #123624
We suggest that add Rich editor type field(to add more information) instead of text type fields, So you/vendor can formatting the text in product manage section how he wants to display n front-end.
- April 27, 2020 at 3:13 pm #123633
Gregorio
Participantworks perfectly. Thanks
