Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Product tags based on admin defined tags
- This topic has 3 replies, 3 voices, and was last updated 6 years, 6 months ago by
- September 2, 2019 at 6:27 am #79548
CommunityCorals
I would recommend to narrow down the product tags to a limited set of tags rather than giving vendor the chance to define their own tags. We had this request in the past and I think you planned to implement it.
This is one of the very rare cases where I prefer the Dokan functionality. Maybe you can check this once again.
Dominique - September 4, 2019 at 6:34 am #79923
Yeah, we will add an option to change “tag input” field to drop-down. Hence vendor will able to choose only from existing tags.
- September 17, 2019 at 6:45 pm #82136
Grégoire Tabeau
ParticipantHi there,
It’s apparently possible to manage tags since the last update. Where we can do this ? Thank you in advance.
- September 19, 2019 at 5:34 pm #82464
Please go to WCFM Admin Setting -> Dashboard -> Check “Disable Tags Input Box” option – https://ibb.co/n6s2kbK
