Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Products & Coupons Add New
- This topic has 4 replies, 3 voices, and was last updated 8 years, 10 months ago by
- November 6, 2017 at 9:44 am #15402
rene
ParticipantHello
When I mouse over products or coupons, the Add New comes
I would like to remove this so that the vendor must first click on Products or coupons so that he sees what he has everything.
Do you have a solution for that? - November 6, 2017 at 11:10 am #15406
WCfM Forum
There is no ready-made solution for this.
If I suggest to hide using Capability then it will be disabled from all over, that will be not write.
CSS is a option but I don’t like such solutions.
As always, i can send you a code snippet to disable those.
- November 6, 2017 at 11:15 am #15407
rene
ParticipantA pity but you can live with that
Thank you - November 6, 2017 at 12:22 pm #15411
WCfM Forum
GuestWell fine, that’s a good idea. And it useless in touch device also.
Will add a dashboard settings for this.
Thanks for this.
Shhiv
- November 12, 2017 at 5:35 am #15639
This setting already added in WCFM latest update.
You will have this under WCFM admin settings -> ModulePlease know us is this works for you or not?
- The topic ‘Products & Coupons Add New’ is closed to new replies.
