wcfm-santa
-364Day -23Hr -24Min -25Sec
wcfm-santa
Re-direct vendor after registration
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Re-direct vendor after registration
Viewing 1 reply thread
    • #107281
      ashley.younguk
      Hello amazing team,
      I would like to re-direct the vendor once they have completed the registration form to a page that I have created. Is this possible?
      Thank you,
    • #107428
      Yes It is possible, if you are using our “WCFM Membership” plugin. Then set your page as “Custom Thank You Page” (<your site url>/store-manager/memberships-settings/ PFA) and turn on the “Disable Store Setup Widget” (settings->Marketplace Settings->Disable Store Setup Widget).
