Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Re-order product categories and Toolset taxonomies at dashboard
- This topic has 3 replies, 2 voices, and was last updated 6 years, 10 months ago by
- September 24, 2018 at 2:21 am #32332
MOHO
ParticipantThe shop manager will need to re-order product categories and Toolset taxonomies sometimes.
But now it have no this function.
I use this plugin re-order at backend.
Advanced Taxonomy Terms Order
https://www.nsp-code.com/premium-plugins/wordpress-plugins/advanced-taxonomy-terms-order/Could you support it at WCfM?
Or you will develop custom re-order function?
If need, i will give you this plugin for test, thanks.
You must be logged in to view attached files. - September 24, 2018 at 8:21 pm #32452
Frankly, we didn’t think about this.
First we want to bring taxonomy manager in frontend.
Off course then we will add such advanced options as well.
You may send me this plugin.
- September 24, 2018 at 8:52 pm #32461
MOHO
Participantok i will sent you
and nsp-code also make this “Advanced Post Types Order”
https://www.nsp-code.com/premium-plugins/wordpress-plugins/advanced-post-types-order/I understand each product have own menu order option, i could set 1,2,3 for change the product position who is first, who is last.
But it not very intuitive for the user to manage. This is why i use their plugin, and paid
I will both sent you, i hope you could check, and support it
You must be logged in to view attached files. - September 24, 2018 at 9:31 pm #32474
MemberThank you, already received.
- The topic ‘Re-order product categories and Toolset taxonomies at dashboard’ is closed to new replies.
