Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Affiliate › Referral rates on a per-product/product group basis?
- This topic has 4 replies, 4 voices, and was last updated 5 years, 10 months ago by
vanilladev89.
- November 12, 2019 at 6:40 pm #91997
vachirakorn
ParticipantHi Team,
How can I set referral rates on a per-product or per product category basis?
I really need this feature because it is essential in my business need.Thank you
- November 22, 2019 at 10:15 am #93379
MemberWe have this in plan, will be there very soon.
- November 23, 2019 at 5:40 am #93497
clarizavelez574
Participanthello please could you help me with 3 necessary news on my site
1 every time I want to generate an affiliate url I get the invalid url message
My site is loading too much, since I installed the plug-in, please could you suggest something to speed up the loading
I miss the google map even though I have already placed the google map api key
attached site address http://www.fegoec.com
You must be logged in to view attached files. - November 26, 2019 at 2:29 pm #94017
Please try to generate affiliate URL for this – http://www.fegoec.com (with https:// part attached)
– Is this showing any error in your site at the place of map? Please be sure you have enabled “Places API” for your map api. You may directly contact Google MAP support for this as well.
- January 8, 2020 at 1:42 pm #101346
vanilladev89
Posting this for any future users. I was testing affiliate and affiliate links and if you add an affiliate through the back end, wcfm URL generator did not work. I had to add them through the front end manager in order for the URL generator to function properly. Also, don’t forget the https://
Cheers
-VD
- The topic ‘Referral rates on a per-product/product group basis?’ is closed to new replies.
