Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Registration Store Locator
- This topic has 2 replies, 2 voices, and was last updated 5 years, 3 months ago by
luis.samouco.
- June 1, 2020 at 1:14 am #137075
luis.samouco
ParticipantHello WCLOVERS,
When a vendor register in my website (Vendor registration page) they will go through the wizzard and they will have 2 places where they need to add their store address. The 1ª one gets the text to put in the store page and the 2º one gets the geolocation that is used in the store list and shop page.
Is there any way join both search addresses fields just into one? Like one that does both geolocation and text information?
Thank you for your help!Attachments:
You must be logged in to view attached files. - June 1, 2020 at 12:48 pm #137228
Sarmistha Chakraborty
By-default it’s not possible. The “Find Location” requires for a map point. Also the “Store Address” is required for display vendor address.
Unfortunately Merging two fields is not possible using a code snippet.Thanks.
- June 2, 2020 at 1:49 am #137451
luis.samouco
ParticipantThank you a lot for your reply! Thank you!
