Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Removal of Notification / Enquiry number alert
- This topic has 10 replies, 4 voices, and was last updated 8 years, 7 months ago by
- March 11, 2018 at 5:50 am #20133
info31
ParticipantHi there
How do I removal of numbers on top of Notification / Enquiry if there are no notifications/enquiries.
Ideally, the numbers should only show when there is a Notification / Enquiry.
Thank you.
- March 11, 2018 at 4:18 pm #20147
“Ideally, the numbers should only show when there is a Notification / Enquiry.” – This is not possible to achieve using any PHP or CSS, if so then you have to edit the core files.
If you really want to achieve this then may use some JavaScript.
Or you may totally remove count display using CSS.
- March 11, 2018 at 4:27 pm #20150
info31
ParticipantIs that achieved easily?
Could you kindly send me the code?
Thank you.
- March 11, 2018 at 9:59 pm #20168
Bingal
KeymasterOK, I will give you that.
- March 12, 2018 at 1:56 am #20178
info31
ParticipantThank you Bingal. I appreciate all your help.
The level of support from WC Lovers has been amazing.
- March 12, 2018 at 5:37 am #20191
Here is your code for the purpose –
jQuery(document).ready(function($) { function wcfmMessageCounthide() { $notice_count = parseInt( $('.notice_count').text() ); $message_count = parseInt( $('.message_count').text() ); $enquiry_count = parseInt( $('.enquiry_count').text() ); if( !$notice_count ) { $('.notice_count').hide(); } else { $('.notice_count').show(); } if( !$message_count ) { $('.message_count').hide(); } else { $('.message_count').show(); } if( !$enquiry_count ) { $('.enquiry_count').hide(); } else { $('.enquiry_count').show(); } setTimeout(function() { wcfmMessageCounthide(); }, 10000 ); } wcfmMessageCounthide(); });Please be careful it’s a JavaScript code, not PHP.
Shhiv - March 12, 2018 at 5:12 pm #20232
info31
GuestHi there,
I’ve entered it into the custom javascript in my site:
https://imgur.com/a/QfYl2Unfortunately, the numbers still remain.
https://imgur.com/a/OQuBP - March 13, 2018 at 9:34 am #20251
Bingal
KeymasterI send you a mail regarding this.
I must say, your site is crazy.
PHP, JS – no custom codes work ..
- March 13, 2018 at 4:24 pm #20301
Kevin
GuestThat is why I’m so stumped. It seems like all other codes work. Only the ones provided by WCFM (which is very bizarre).
Thank you for all the help. I’m no very good in code, so I need all the help I can get.
Is the code right? Am I installing it in the right place?
- March 15, 2018 at 8:14 am #20353
Kevin
GuestHi. Following up on this.
- March 15, 2018 at 8:18 am #20356
MemberIt’s resolved.
Code added wrongly, garbage character as there.Thank You
- The topic ‘Removal of Notification / Enquiry number alert’ is closed to new replies.
