wcfm-santa
The New Year has begun! Avail upto 25% OFF on WCFM Addons.
03Day 04Hrs 22Min 36Sec
Remove Billing/Shipping info
Viewing 6 reply threads
    • #17359
      Sergio
      Hey there. Thanks for the great product.
      Mine is for digital downloads and cryptocurrency so I was wondering how I can remove the Billing/Shipping info from the checkout page.
      Thank you.
    • #17365
      That’s totally depending upon WooCommerce setup.
      You may easily disable Shipping from WooCommerce settings.
      For manipulating Billing fields you may take help of WooCommerce checkout field manager plugin and disable all woocommerce payment gateways.
      Hope your crypto currency definitely comes with some option at WooCommerce checkout for processing order!
    • #17381
      Sergio
      Yep, my cryptocurrency is compatible.
      Anyway… it’s not working still. I attached some screenshots of it. If possible, not sure if this is in woocommerce or dokan, but I could go into the code and try to fix it (and not break it) but I didnt know which file to edit.
      https://imgur.com/a/CFMgf
    • #17382
      Sergio
    • #17383
      Sergio
      I also found a code for automatic Soundcloud embeds but still looking where the file is and where to paste it.
      // Add SoundCloud oEmbed
      function add_oembed_soundcloud(){
      wp_oembed_add_provider( ‘http://soundcloud.com/*’, ‘http://soundcloud.com/oembed’ );
      add_action(‘init’,’add_oembed_soundcloud’);
    • #17388
      First of all, set WooCommerce “Shipping Destination” settings to “Default to customer billing address”.
      You may add such custom codes in your child theme’s functions.php
      I am not have enough knowledge of embed code but I think there has few plugins for that.
      I had once work with this add-on, not sure is this will helpful for you anyway or not – https://wordpress.org/plugins/music-player-for-woocommerce/
    • #17543
      Can we help you any other way?
  • The topic ‘Remove Billing/Shipping info’ is closed to new replies.
