Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Remove "Change or Upgrade your current membership plan"
- This topic has 7 replies, 3 voices, and was last updated 6 years, 7 months ago by
- October 24, 2019 at 1:11 pm #88793
aemr45
ParticipantHi, in order to force vendors to cancel membership plan before changing or updating, I need to remove the access to “Change or Upgrade your current membership plan” from vendor’s profile membership (shown in pic)
This is because changing plan with this function does not cancel stripe’s membership and products stay the same, and I need to go to draft for product limitation.
You must be logged in to view attached files. - November 5, 2019 at 6:08 pm #90815
add_filter( 'wcfm_is_allow_change_membership', '__return_false' );Add this code to your child theme’s functions.php
- November 5, 2019 at 11:04 pm #90915
- November 7, 2019 at 5:08 pm #91297
Sarmistha Chakraborty
Try this code to your child theme’s style.css,
div#wcfm_profile_manage_form_membership_expander h2 { display: none; }Thanks.
- November 11, 2019 at 7:33 am #91748
aemr45
The plugin Snippets its showing that there is something wrong (pic attached), is it safe to add this code anyway?
You must be logged in to view attached files.- November 11, 2019 at 11:30 am #91766
Please add the above script to your theme’s style.css. This is not php script, it’s css script.
What we understand that, you are using “Code Snippets” plugin. for this add below code,add_action( 'wp_footer', function() { ?> <style> div#wcfm_profile_manage_form_membership_expander h2 { display: none; } </style> <?php } );Thanks.
- November 12, 2019 at 3:28 am #91876
aemr45
ParticipantHi, that’s correct. this code worked with code snippets.
Thank you very much!
- November 12, 2019 at 9:18 am #91902
MemberYou are always welcome 🙂
- The topic ‘Remove "Change or Upgrade your current membership plan"’ is closed to new replies.
