Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Remove "Product video" and "Product 360 view" tabs
- This topic has 10 replies, 2 voices, and was last updated 5 years, 8 months ago by
marcinzywy.
- November 23, 2019 at 6:38 pm #93646
marcinzywy
ParticipantI would like my vendors to be able to add only images to their products. Therefore, I would like to remove ‘Product video’ and ‘Product 360 view’ tabs from ‘Product->Add New’ in vendor dashboard. However, I couldn’t find any option for this in my WCFM Ultimate. Thanks for the help.
- November 23, 2019 at 7:11 pm #93653
marcinzywy
ParticipantBy the way, I thought this option would be under Integrations in Capabilities, however it’s not there. See the screenshot:
You must be logged in to view attached files. - November 26, 2019 at 3:07 pm #94035
MemberYeah, those should be here. What is your WCFM Ultimate version?
- November 26, 2019 at 3:17 pm #94039
marcinzywy
ParticipantHi, thank you for your reply. I got these plugins installed:
WCFM – WooCommerce Frontend Manager – Version 6.3.4
WCFM – WooCommerce Frontend Manager – Ultimate – Version 6.3.4
WCFM – WooCommerce Multivendor Marketplace – Version 3.2.6
WCFM – WooCommerce Multivendor Membership – Version 2.7.4
WooCommerce – Version 3.8.0 - December 2, 2019 at 2:50 pm #95483
marcinzywy
Participanthi, any update on this?
- December 7, 2019 at 10:56 am #96372
I would like to remove ‘Product video’ and ‘Product 360 view’ tabs – Kindly show me these two tabs screenshot please.
These are not WCFM direct integration. Are you using any custom plugin for integrating these addons?
Product 360 view – is this product’s 360 degree images? If so, then please check for capability “360° Images”
- December 9, 2019 at 4:47 pm #96751
marcinzywy
ParticipantHi, thank you for reply.
I use Martfury paid theme – version: 2.1.1 and think these additional features come from the theme functionality.
However, there is no option in Martfury settings to turn off video and 360 degree. I will ask for solution on Martrufy forum.
I have attached the screenshot so you can have a look.
You must be logged in to view attached files. - December 10, 2019 at 10:02 am #96831
Please go to WCFM Capability Setting and check under “Integrations” section.
- December 11, 2019 at 3:22 pm #97030
marcinzywy
Like I said in my second post – there is nothing under ‘Integrations’ in Capabilities.However, I posted info on Martfury Theme forum and they will solve this with the next update.
Not sure why there is nothing under ‘Integration’ though.
- December 12, 2019 at 5:17 pm #97236
MemberWhat is your WCFM Free and WCFM Ultimate plugin’s versions?
Please be sure your WCFM Ultimate plugin’s installation folder name is – “wc-frontend-manager-ultimate”
- December 15, 2019 at 3:07 pm #97540
marcinzywy
I posted this above on November 26.
Thank you for your help.
- The topic ‘Remove "Product video" and "Product 360 view" tabs’ is closed to new replies.
