Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Remove the virtual and downloadable product check boxes
- This topic has 3 replies, 3 voices, and was last updated 5 years, 5 months ago by
- March 4, 2020 at 9:11 am #109819
Sheila
ParticipantHi, everybody, I’m Sheila.
I hope you’re all right. I was wondering if someone could please help me with the snippet code to hide the two check boxes I marked in the attached picture.
The one in Virtual and Downloadable.
Because it creates a lot of confusion in the users of the web.
Thanks in advance.
You must be logged in to view attached files. - March 4, 2020 at 1:07 pm #109843
KeymasterHello,
You can disable these two checkboxes(virtual, downloadable) from Admin dashboard >> Capability under Types disable Virtual and Downloadable option.
Ref – https://ibb.co/wJzC6Gz
Thanks! - March 6, 2020 at 5:38 am #110193
claire-0118
ParticipantHi Sushobhan,
I was also looking to disable these checkboxes however, those options do not show in my install. I have the latest FREE plugin version, is this function only available on the paid version?
Cheers,
Claire - March 6, 2020 at 12:25 pm #110220
KeymasterHi Claire,
Yes, its a part of our Ultimate plugin. Sorry I forget to mention that earlier. But, if you want to only hide virtual and downloadable options, you won’t need the ultimate plugin, use the following snippet for that-function disable_virtual_downloadable_support( $general_fields ) { if ( isset( $general_fields['is_virtual'] ) ) unset( $general_fields['is_virtual'] ); if ( isset( $general_fields['is_downloadable'] ) ) unset( $general_fields['is_downloadable'] ); return $general_fields; } add_filter( 'wcfm_product_manage_fields_general', 'disable_virtual_downloadable_support' );
