Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › remove tiny mce
- This topic has 3 replies, 3 voices, and was last updated 6 years, 6 months ago by
- January 14, 2020 at 7:57 am #101975
jorsenmejia
Participanthow to remove tiny mce on product manager fields?
- January 14, 2020 at 8:04 am #101976
jorsenmejia
ParticipantTake note for admin side*
- January 14, 2020 at 1:42 pm #101995
KeymasterIf you want to disable Tiny MCE editor completely in WCFM dashboard you can use the following snippet –
function disable_tiny_mce_editor($allow) { return ''; } add_filter('wcfm_is_allow_rich_editor', 'disable_tiny_mce_editor', 501);Add this code to your child theme’s functions.php
By the way, what do you mean by “Take note for admin side*”? Does it mean, you want to only disable Tiny mce editor for vendors? If that is the case please use the following snippet.
function disable_tiny_mce_editor_for_vendors($allow) { if( wcfm_is_vendor() ) return ''; return $allow; } add_filter('wcfm_is_allow_rich_editor', 'disable_tiny_mce_editor_for_vendors', 501); - February 7, 2020 at 11:34 am #106038
If you are using WCFM Ultimate then may manage this from WCFM Capability setting as well.
Please set OFF “Rich Editor” from WCFM Capability setting – https://ibb.co/9V7Sgnw
- The topic ‘remove tiny mce’ is closed to new replies.
