remove tool tip and move field description to below field.
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate remove tool tip and move field description to below field.
Viewing 4 reply threads
    • #109384
      wpxpert
      where I need to make changes.
    • #109897
      Please add this code to your site for the purpose-
      add_filter( 'wcfm_product_manage_fields_advanced', function( $advance_fields, $product_id ) {
      	if( isset( $advance_fields['menu_order'] ) ) {
      		$advance_fields['menu_order']['desc'] = $advance_fields['menu_order']['hints'];
      		$advance_fields['menu_order']['desc_class'] = 'wcfm_page_options_desc';
      		unset( $advance_fields['menu_order']['hints'] );
      	return $advance_fields;
      }, 50, 2 );
    • #110207
      wpxpert
      Thanks for the code. its working fine.
      but I need to do for all tooltip in wcfm.
    • #110752
      wpxpert
      HI, I did you read my comments?
    • #110949
      For “Advance” menu,
      Add this code,
      	if( isset( $advance_fields['purchase_note'] ) ) {
      		$advance_fields['purchase_note']['desc'] = $advance_fields['purchase_note']['hints'];
      		$advance_fields['purchase_note']['desc_class'] = 'wcfm_page_options_desc';
      		unset( $advance_fields['purchase_note']['hints'] );
      }, 50, 2 );
      Regarding all tooltip in WCFM,
      Like above script you have to write in similar way for different filters.
      example: For inventory SKU,
      add_filter( 'wcfm_product_fields_stock', function( $fields, $product_id, $product_type ) {
      		$fields['sku']['desc'] = $fields['sku']['hints'];
      		$fields['sku']['desc_class'] = 'wcfm_page_options_desc';
      		unset( $fields['sku']['hints'] );
      	return $fields;
      }, 50, 3 );
      You can find filters in wp-content/plugins/wc-frontend-manager/views/products-manager/wcfm-view-products-manage-tabs.php file.
  • The topic ‘remove tool tip and move field description to below field.’ is closed to new replies.
