Remove virtual & downloadable products selection?
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace Remove virtual & downloadable products selection?
Viewing 3 reply threads
    • #97389
      voc.marcello
      How Remove virtual & downloadable products selection?
    • #97532
      Turn off the “virtual” and “downloadable” product capability from store-manager dashboard. (PFA)
    • #97551
      voc.marcello
      I not have this in my store-manager dashboard.
      • #98892
        You have this under WCFM Dashboard -> Capability Setting
        If you are using only WCFM Free addon then add this code for the purpose-
        add_filter( 'wcfm_product_manage_fields_general', function( $general_fields, $product_id, $product_type ) {
        	if( isset( $general_fields['is_virtual'] ) ) {
        		$general_fields['is_virtual']['class'] = 'wcfm_custom_hide';
        		$general_fields['is_virtual']['desc_class'] = 'wcfm_custom_hide';
        	if( isset( $general_fields['is_downloadable'] ) ) {
        		$general_fields['is_downloadable']['class'] = 'wcfm_custom_hide';
        		$general_fields['is_downloadable']['desc_class'] = 'wcfm_custom_hide';
        	return $general_fields;
        }, 50, 3 );
    • #97640
      Setup the WCFM page from WCFM options (PFA).
      Or can you share us the site admin details. Then we can check your settings.
  • The topic ‘Remove virtual & downloadable products selection?’ is closed to new replies.
