Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Removing "Add to Cart" from Category Page
- This topic has 19 replies, 2 voices, and was last updated 6 years, 7 months ago by
- July 24, 2019 at 5:41 pm #73758
puppycircles
ParticipantIs there a way to remove the “add to cart” button from a category page? I have used the catalog mode for the individual product but the “add to cart” button still appears when you hover over the thumbnail on the category page (see attachment). I would like the rule to apply to all products in a particular category.
You must be logged in to view attached files. - July 24, 2019 at 10:31 pm #73789
puppycircles
ParticipantFollow-up question:
My site operates as a catalog of available “products”. Is there a way to make all vendors operate in catalog mode by default?Thanks again
- July 25, 2019 at 1:44 pm #73889
Please add this line to your site –
add_filter( 'woocommerce_is_purchasable', '__return_false' );Thank You
- July 25, 2019 at 3:14 pm #73922
puppycircles
ParticipantThank You! The only issue with the filter that you provided is it is shuts down all woocommerce purchases. Generally this is fine for all vendors however I charge a reoccurring annual membership fee, so I need the filter to allow a category of products (Vendor Memberships) to be sold. The there an easy way to make some product categories purchasable and other not? Does the “Ultimate” or any of the other addons have this function?
- July 26, 2019 at 1:03 pm #73996
This is off course possible. Please know me that category ID. I will change code accordingly.
- July 26, 2019 at 4:49 pm #74058
puppycircles
ParticipantThank you! The only category I want to be purchasable is “Vendor Memberships”
- July 29, 2019 at 12:57 pm #74373
MemberUnderstand. Create such a category and know me it’s ID.
- July 29, 2019 at 2:31 pm #74392
puppycircles
ParticipantHi There! Just wanted to make sure you received my previous reply. You had provided me with the code:
add_filter( ‘woocommerce_is_purchasable’, ‘__return_false’ );
I requested for a way to make some product categories purchasable and others not. The category I want to be made purchasable is “Vendor Memberships”
Thanks so much for your help!
- July 29, 2019 at 9:26 pm #74429
puppycircles
ParticipantI do not know where to find the category ID. I have created a parent category “vendor memberships”. Are you referring to the product IDs for the products within that category? Currently the only product under that parent category is “basic vendor memberships: with an ID:471. Is this what you are referring to?
- July 30, 2019 at 3:49 am #74460
puppycircles
ParticipantOkay, I found the category ID: cat&tag_ID=197
Sorry, I am new to this and learning as I go.
Thanks again for you help!
- July 31, 2019 at 8:06 pm #74655
puppycircles
ParticipantSorry, Just following up on this request…
- August 3, 2019 at 5:34 am #74926
– What category you have created? Post or Product?
You have to create “Product Category” and then edit that and you will see like this – https://ibb.co/VW0Q6KM
- August 5, 2019 at 3:30 am #75240
puppycircles
ParticipantI have created a product category “vendor memberships”: wp-admin/term.php?taxonomy=product_cat&tag_ID=197&post_type=product&wp
- August 8, 2019 at 3:56 pm #75786
Here is your modified code for the purpose –
add_filter( 'woocommerce_is_purchasable', function( $is_purchasable, $product ) { $pcategories = get_the_terms( $product->get_id(), 'product_cat' ); if( !empty($pcategories) ) { foreach($pcategories as $pkey => $pcategory) { if( absint($pcategory->term_id) == 197 ) { $is_purchasable = false; } } } return $is_purchasable; }, 500, 2 );Thank You
- August 9, 2019 at 6:02 am #75865
puppycircles
ParticipantThank you,
Unfortunately the code did not work the way I hoped. Vendor products are still purchasable in product pages and the vendor membership was not purchasable.
Can we talk about customized work.
You must be logged in to view attached files. - August 12, 2019 at 8:52 am #76207
Please use this modified code –
add_filter( 'woocommerce_is_purchasable', function( $is_purchasable, $product ) { $is_purchasable = false; $pcategories = get_the_terms( $product->get_id(), 'product_cat' ); if( !empty($pcategories) ) { foreach($pcategories as $pkey => $pcategory) { if( absint($pcategory->term_id) == 197 ) { $is_purchasable = true; break; } } } return $is_purchasable; }, 500, 2 );Thank You
- August 17, 2019 at 4:55 am #77020
puppycircles
ParticipantThank You for the modified Code! IT WORKS!
- August 20, 2019 at 8:12 am #77459
MemberYou are always welcome 🙂
Can we ask for a favor? Would you mind taking a few minutes to review our plugin at https://wordpress.org/support/plugin/wc-multivendor-marketplace/reviews/ and let others know about your 5 Star experience with WCFM Marketplace. Also, follow us on Twitter https://twitter.com/wcfmmp for more exciting news, important updates, and irresistible offers. - August 21, 2019 at 4:27 am #77586
puppycircles
ParticipantDone! Thanks again,
Zeke
PuppyCircles.com - August 22, 2019 at 5:08 pm #77828
MemberThank you very much and have a great day 🙂
- The topic ‘Removing "Add to Cart" from Category Page’ is closed to new replies.
