Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Replace Dokan method shipping by a table rates
- This topic has 4 replies, 2 voices, and was last updated 7 years, 4 months ago by
- February 14, 2018 at 8:49 am #19081
Chris0483
GuestHello,
Is it possible to replace the Dokan method shipping by a table rates shipping ? Because many vendors on our sites can not properly configure the DOkan shipping system.
I think that replacing it with a system like Table Rates Shipping is more understandable and easier to set up because most sellers apply a delivery fee based on the weight of the products, with a delivery free from an amount of purchase for some of them.
Do you think to integrate it, in the future ?
Best regards
- February 14, 2018 at 8:59 am #19082
I understand your concern, but unfortunately Dokan does not works with Table Rate Shipping.
Only WC Marketplace works with Table Rate Shipping for vendors.
Frankly, we are limited here as well, it’s just not adding shipping setting but also vendor specific shipping calculation is essential, and that’s totally part of multi-vendor plugin.
Can you please confirm once from Dokan support forum, are they support Table Rate shipping vendor wise or not?
I have never heard this so I asked you to confirm once more.Thank You
- February 14, 2018 at 8:31 pm #19121
Chris0483
Guestno it is not supported by Dokan, but I think that would be a good modification
- February 15, 2018 at 6:50 am #19137
MemberYeah, that’s true but without Dokan core support how this can be possible I have to check.
- February 15, 2018 at 6:52 am #19138
MemberWooCommerce has a add-on “Per Product Shipping” – https://woocommerce.com/products/per-product-shipping/
Take a look if this is somehow helpful for your case.
- The topic ‘Replace Dokan method shipping by a table rates’ is closed to new replies.
