Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Report Problem on WCFM .
- This topic has 5 replies, 2 voices, and was last updated 7 years, 2 months ago by
- June 18, 2018 at 5:30 am #25037
nakedharmonix
Even if I delete an order, it will not be reflected in the report on WCFM .
I checked the backend, the order has been successfully deleted.Thank you
TK - June 18, 2018 at 5:47 am #25039
Is this for Admin report or vendor report?
Admin reports get some time to be refreshed due to transient. Or you may check by clearing transient manually.
- June 18, 2018 at 5:53 am #25041
nakedharmonix
>Or you may check by clearing transient manually.Can I check documentation about this?
thank you
TK - June 18, 2018 at 5:59 am #25043
You may clear transient from – wp-admin -> WooCommerce -> Status -> Tools
Well, is your WC Reports showing right data now?
- June 18, 2018 at 6:15 am #25044
nakedharmonix
The backend report is displayed correctly.
WCFM reports are not synchronized normally.Thank you
TK - June 19, 2018 at 11:11 am #25118
We are checking this.
- The topic ‘Report Problem on WCFM .’ is closed to new replies.
