Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Reviews kept showing "Your review is awaiting approval"
- This topic has 9 replies, 2 voices, and was last updated 7 years, 8 months ago by
- February 18, 2019 at 5:31 am #48674
samsun34567
ParticipantHi team,
The reviews posted keep showing status of “Your review is awaiting approval” even when auto-approve is checked and it appears in the “approved” tab in vendors back-end.
How can I solve this?
- February 18, 2019 at 5:06 pm #48788
Is this for product review or vendor review?
- February 19, 2019 at 3:26 am #48875
samsun34567
It’s for product review.
- February 19, 2019 at 10:31 am #48923
samsun34567
ParticipantOn further testing, I found the reviews left for a single product actually ends up in the vendor review.
Basically, if left a review for single product ->
1. Shows “Your review is awaiting approval” on single product page
2. Shows up in vendor review in vendor store page.
- February 19, 2019 at 10:52 am #48946
1. WCFM has no control over product review.
2. Shows up in vendor review in vendor store page. – it’s default feature, don’t you have “Reviews” tab under store page?
- February 20, 2019 at 3:59 am #49082
samsun34567
ParticipantOHHH okay, I thought the review tab in single product page is for product review, turns out it’s for vendor review! Got it.
Think I’ll disable the vendor review altogether. Thanks!
- February 20, 2019 at 4:12 am #49083
samsun34567
ParticipantOkay I can’t seem to disable it.
I turned reviews off in modules, also turned off review manage in capabilities. It still appears though.
What can I do?
- February 20, 2019 at 5:02 am #49099
Please use this code snippet –
add_filter( 'wcfmmp_store_tabs', function( $store_tabs, $store_id ) { if( isset( $store_tabs['reviews'] ) ) unset( $store_tabs['reviews'] ); return $store_tabs; }, 50, 2 );Thank You
- February 20, 2019 at 6:56 am #49117
samsun34567
ParticipantOkay thanks! That works.
So a suggestion here:
What got me confused is that the single product review goes into vendor review, but at the same time you can review the vendor directly, which is all mixed together and quite confusing.
Why don’t you separate the 2 kinds of reviews ->
1. You can aggregate all the single product reviews in the vendor page while showing which products they are.
2. Use another review for vendor itself, or simply disable it and show the average of all the single product review.
Here is a similar website which I think did a good job on the reviews, for your reference: https://www.pinkoi.com/user/blissandhome?onload=cb_review#~review
- February 20, 2019 at 7:41 am #49120
– it’s already there2. Use another review for vendor itself, or simply disable it and show the average of all the single product review.
– it’s also possible to provide separate review directly to vendors.Thank You
- The topic ‘Reviews kept showing "Your review is awaiting approval"’ is closed to new replies.
