00Day 23Hr 06Min 32Sec
Save/draft buttons – Compatibility issue with 123 Garden Theme
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Save/draft buttons – Compatibility issue with 123 Garden Theme
Viewing 4 reply threads
    • #16503
      dani1341
      Hello, after the last update there seems to have appeared a specific issue with the theme we are using (123 Garden)
      https://screenshots.firefox.com/T49i0k1Z3ogsZK6l/babahaus.shop
      The issue is on all browsers (Edge, Internet Explorer, Chrome and Firefox)
      Danial
    • #16522
      Really sorry for the inconveniences but this is a simple CSS z-index issue.
      Your theme footer somehow set at very high z-index which push the WCfM Save bar in back.
      If you are comfortable with CSS then can solve this very easily otherwise we can also help you to fix this but then we have to access your site once to check exact suitable z-index for your site.
      Thak You
    • #16523
      dani1341
      Is it possible to have an option to change to to the old position of the buttons?
    • #16542
      Simha
      Yeah right.
      We are going to add a settings option to disable Float button in next version.
    • #16603
      WCFM new version has just released.
      We have added a Dashboard Settings “Disable Float Button”, kindly use this for your theme.
      Please know me is this resolve your issue or not!
  • The topic ‘Save/draft buttons – Compatibility issue with 123 Garden Theme’ is closed to new replies.
